truing a laced wheel
  • franknsr
  • franknsr's Avatar Topic Author
24 Jan 2009 20:28
#259998
Got my new tire on the rim, new bearings installed, dug a path through the snow to the shed today to install the wheel and found out I’m not done. That sucker hops up and down like a pogo stick. I thought the problem was with the old tire so I lived with it for a while, now I realize it’s in the rim.
Is truing my wheels something I can attempt or is a professional recommended? Any idea’s on cost if I have it done?
Formerly CSRchopper
1991 KZ1000P
Gone but not forgotten
1986 ZG1000
1982 650 CSR -shoulda kept this one-
Lisle Illinois, USA
  • PLUMMEN
  • PLUMMEN's Avatar
Re: truing a laced wheel
24 Jan 2009 20:37
#259999
hopping as in bouncing/shaking,did you balance the tire after installing it ? being out of true would usually cause a wobble B)
  • franknsr
24 Jan 2009 20:52
#260004
Hopping like moving up an down when I spin it. There is no latteral movement at all, just up and down.
I did not balace it, but I'm not spinning it fast enough to induce any kind of compression of the springs.
Formerly CSRchopper
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
  • Kawickrice
  • Kawickrice's Avatar
24 Jan 2009 20:54
#260006
Sometimes the tire will not seat right and cause a pogo hop. There is usually some sort of moulded line near the rim on the tire, if you visually watch the line you will see it disappear into the rim and then reappear. I have had to break down tires multiple times to get it right.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • franknsr
24 Jan 2009 21:03
#260010
Yup, I experienced that last time around. When I spin the wheel this time I can watch the rim and the tire going up and down. I’m sure it’s the wheel.
Formerly CSRchopper
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
  • PLUMMEN
  • PLUMMEN's Avatar
24 Jan 2009 21:09
#260014
if the rim is actually egg shaped truing wont help,pull it off and have it balanced at a shop to make sure.B)
  • gane
  • gane's Avatar
25 Jan 2009 18:27
#260181
Chopper.before going nutz.make your'self an indicator. get the bike so's wheel can be spun whilst mounted. anything, a pile of bricks/ ruler whatever, and watch rim run-out at inside of rim. this will tell if rim is true to hub. then check at outside. this will reveal possible rim ding.; flatted rim. spoked wheels are fit, 1st up &down then side to side. with most specs being less than a mm. for either. I hope for your' sake you've. a crappy tire or it's not seated, trying to take the hop out of a 30 year-old rim usually begins w/ spokes & hoop. G
[img][/img] 1977 KZ1000A1
  • jzanutto
  • jzanutto's Avatar
25 Jan 2009 19:53 - 25 Jan 2009 19:54
#260203
they have these at harbor freight. you could make something like it to hold the axle while spinning the wheel, then you need some type of non-movable pointer that will point at the rim and give you a reference for out of round condition
1978 KZ650B 2004 BMW R1150RT
Last edit: 25 Jan 2009 19:54 by jzanutto.
  • BSKZ650
  • BSKZ650's Avatar
26 Jan 2009 05:21 - 26 Jan 2009 09:54
#260238
are you sure its not the bearings causing this? even though they are new, maybe one was damaged on install?
77 ltd1000, current rider
76 kz900, just waiting
Last edit: 26 Jan 2009 09:54 by BSKZ650.
  • PLUMMEN
  • PLUMMEN's Avatar
26 Jan 2009 07:54
#260271
weld an old steel swingarm to a plate! :laugh:
  • jzanutto
  • jzanutto's Avatar
26 Jan 2009 20:24
#260410
yep. whats the latest on the money green 1000?
  • franknsr
04 Feb 2009 09:04
#262134
Thanks for the help guys. I set up a truing stand in the basement...er..I mean workshop and actually have this thing spinning much better that it was. I can't make it perfect because the wheel is egg shapped, just like Plummen said. How'd you know Plummen, without even seeing it! Hmmmmm.....
Formerly CSRchopper
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
