1983 750 GPZ
  • Shoe48
  • Shoe48's Avatar Topic Author
  • Live each day as it is your last
1983 750 GPZ
13 Jan 2009 08:55
#257655
Anyone ever change the handlebars to something higher ? I have looked through the archives with no good answer , I thought I saw somewhere that you could use GPZ900 handlebars But there is a differance in Fork Diameters ,, any thoughts ? Thanks Shoe
  • trianglelaguna
  • trianglelaguna's Avatar
Re: 1983 750 GPZ
13 Jan 2009 09:03
#257656
a top triple tree from a kz 750 and some old school superbike bars would be cool...i'm trying to post a shot of wayne raineys superbike gpz 750....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • Shoe48
Re: 1983 750 GPZ
13 Jan 2009 13:51
#257683
I will look into it :)
  • Kawickrice
  • Kawickrice's Avatar
Re: 1983 750 GPZ
13 Jan 2009 13:58
#257687
If you are raising the bars make sure your cables are long enoughB)
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • steell
  • steell's Avatar
Re: 1983 750 GPZ
13 Jan 2009 19:13
#257766
Forget using the KZ750 top triple clamp on the GPz750 forks, the KZ750 is 36mm and the GPz is 37mm (83-85).
Get the handlebar holders off a 85 GPz750, they're about an inch taller than the 83 are.
  • Shoe48
Re: 1983 750 GPZ
13 Jan 2009 20:49
#257776
Thanks Steel I thought someone would know :)
  • gane
  • gane's Avatar
Re: 1983 750 GPZ
13 Jan 2009 21:07
#257777
Another thought, dirt bike risers which convert 7/8" bars to 1" raise bars @ 1 " and allow pro-tapers. No mod to upper clamp, a variety of stiff bars in diff, bends & lengths. Bars are expensive, but surely no more than machining/swapping upper clamps. G
[img][/img] 1977 KZ1000A1
  • Shoe48
Re: 1983 750 GPZ
19 Jan 2009 14:30
#258834
The GPZ uses a clip om type of bar that has a unusual mounting , I found a set of 85 bars off ebay , I guess 84 is the same also ,,, Thanks for the input :)
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
Re: 1983 750 GPZ
19 Jan 2009 19:11
#258882
Easily remedied by boring the diameter out a mil. Did it w/ some clip-ons from a Suzuki once for my "J".
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
  • steell
  • steell's Avatar
Re: 1983 750 GPZ
20 Jan 2009 04:31
#258953
How do you determine the maximum amount that can be removed while still maintaining the required strength?
That's why I never recommend that someone bore a triple clamp, I have no way of answering that question.
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
Re: 1983 750 GPZ
22 Jan 2009 08:41 - 22 Jan 2009 08:45
#259352
With the clip-ons there was PLENTY of meat left, so it wasn't an issue. I have a GS1150ES that I'm throwing gixxer suspension on; the gixxer forks are conventional and only 2mm larger than the 1150 forks and I'm going with gixxer triples and boring the stock clip-ons out the 2mm. Again, plenty of meat on 'em, so it's not a problem. If you go removing half the material or something, that's probably a bad idea, but in the cases that I've had it's never even been a consideration.
And remember 2mm of 'bore' is only 1mm worth of material (1mm in each direction).
78 Kawasaki Z1R
70 Kawasaki KV75
Last edit: 22 Jan 2009 08:45 by Bad Kaw.
  • steell
  • steell's Avatar
Re: 1983 750 GPZ
22 Jan 2009 15:29
#259454
So you're talking about boring out the clip-ons and not the triple clamp?
I worry about things :D
