My custom 650 rearsets with no frame mods
  • SLEEPER650
  • SLEEPER650's Avatar Topic Author
Re: My custom 650 rearsets with no frame mods
13 Jan 2009 15:08
#257708
brake side
78 650sr my baby
78 650sr waiting for rebuild
82 kz1100
  • Old Man Rock
  • Old Man Rock's Avatar
14 Jan 2009 02:34
#257806
Wholly crapola... WTF with the chain... Is it me or is that bone friggin dry and rusted....
Interesting... Smooth shifting or still work in progress?
Not bad idea....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • SLEEPER650
14 Jan 2009 14:33
#257895
the chain is just for length i installed a kz1000 swing arm and need to know how many links i need.
78 650sr my baby
82 kz1100
  • shortyyyyyy
  • shortyyyyyy's Avatar
22 Jan 2009 03:47
#259319
I'm watchin' this for future mod........ keep the pics commin' as you progress!!
  • galaxian
  • galaxian's Avatar
22 Jan 2009 06:19
#259337
It looks a bit cluttered to me but maybe its still in progress? You can fit modern rearsets from a r1 or gsxr without drilling the frame and they will look cleaner and may be more functional and feel better. Just a thought. On my 1000 i am running R1 rearsets and just had to make a small bracket to fit. They can be removed and the stock ones can be refitted. Just a thought.
1977 KZ1000A1, 1979 KZ650 C3
  • trianglelaguna
  • trianglelaguna's Avatar
22 Jan 2009 08:07
#259346
i'm sure most folks with the big fours(900-1000) allready know this trick for rear sets....but....you can take the foot peg brakets off the frame and flip them over and reverse the left and right sides and re-install em upside down on the other sides of the frame...then pull the pins that hold the pegs and flip the pegs over and put the pins back in so the peg will fold the right way again...i got a shorter shift lever....and i have long feet....the only dif is i look like rossi setting up for a down shift into the corners,,,as i have to flip my foot off and do my clicks down....i also have to shift to my heel on the peg to rear brake....i've been setting mine up like this all my life ...so i don't notice the stretch anymore..and i get to tuck my feet up and back alot more....anyone ever seen this method???? i can send a pic if anyone is interested...takes ten minutes and works just like tarrozis for 0 $...coolio
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
22 Jan 2009 10:00
#259363
Flipping the mounts from side to side (left to right) works on the 650s as well, the ones that use the two bolt mounted pegs.
The one bolt mounted pegs of the early 650 wont swap like that. :(
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • PLUMMEN
  • PLUMMEN's Avatar
22 Jan 2009 10:40 - 22 Jan 2009 10:41
#259372
can you post a picture?ive thought about that for my current retro hotrod since i need to remount my current rear master cylinder differantly anyway due to swingarm clearance issues .i like the sportbike stuff but it just doesnt work for my current project.
Last edit: 22 Jan 2009 10:41 by PLUMMEN.
  • trianglelaguna
22 Jan 2009 11:06
#259377
here i am trying to post a pic of the set-up...it really gives you a motogp feel(lol) but really it does ..i ride on the balls of my feet anyway when i have this set-up...makes normal pegs feel like floor boards on a cop bike...if a guy can cut and weld the shifter and brakes to come up and shorter...than buying rearsets aftermarket is only for the look ..cuase these are better.....
1976 KZ900
2003 ZX12R
2007 FZ1000
  • trianglelaguna
22 Jan 2009 11:09
#259379
and here is a shot of what the bike looks like...the stock pegs allmost look normal untill you relize that they are way up and back from where thay should be.....i love em and gotta do some cutting and welding someday on the levers...but am used to em now so i don't care....function over fashion every time....peace craig
1976 KZ900
2003 ZX12R
2007 FZ1000
  • trianglelaguna
22 Jan 2009 11:31 - 22 Jan 2009 11:35
#259390
and one more shot showing the shifter side and the upside down peg mounts ..this is the tighter of the two sides and if your grometts are brand new and tight...you gotta take a block of wood and tap the peg mount over the frame bolts ...becuase there is a really tight fit next to the swingarm nut...but once you get it started they DO fit.....peace
1976 KZ900
2003 ZX12R
2007 FZ1000
Last edit: 22 Jan 2009 11:35 by trianglelaguna.
  • PLUMMEN
  • PLUMMEN's Avatar
22 Jan 2009 11:35
#259392
cool thanks!B)
