Frame rust removal
- godsjester71
Frame rust removal
16 Feb 2006 12:17
I've been playing around with different methods of cleaning up my frame (with out media blasting). I've got a cordless drill, a Dremel tool, and my hands.
So far the Dremel with the grinding drum/spool works very well, but can be a bit invasive. The wire brushes take more time and fall apart quickly. Sand paper is laborious but effective.
But getting into the tight places (gusset/tube joints, etc.) have been a bit of an issue (euphemism).
Any tricks or tools or methods or ideas? :blush:
- Mark Whiddon
Re: Frame rust removal
16 Feb 2006 13:02
no other way except blasting really. if you have a compressor you can get a cheap siphon gun blaster that works great if you have a big enough compressor. If you dont you just have to wait and let it catch up but you can use a smaller one.
- RomSpaceKnight
16 Feb 2006 13:05
Go to paint forum and see what people use as far as chemical strippers for paint. Do you need to remove all paint or just rusty areas and rough up rest to except new paint?
- BSKZ650
16 Feb 2006 16:13
you can use some of the chemical rust killers, they work good but you need to knock off the big stiff first with a wire wheel, or you can get it dipped in acid, works good as lond as it is done right, but I think a good blasting would be the best, gives you a good " hook " for the paint to stick to
77 ltd1000, current rider
76 kz900, just waiting
- reborn650
16 Feb 2006 19:55
Hey Godsjester - Try some medium grade steel wool. It is great for scuffing the existing paint so the primer then paint will stick. Worked great for me.
-1998 Jeep TJ Wrangler 4.0 litre for the kids
-1975 Zamboni - The real Italian sportscar fully restored and functioning every winter at our local outdoor playground rink.
Mine is an ecclectic collection of motorized toys - LOL
I have a newspaper route and a web site where you can plan your own funeral life celebration www.mysendoff.com ....and go out with your own style.
- steell
16 Feb 2006 23:00
I would not suggest using a wire wheel on a Dremel and running it at high speed. I tried that one time and spent two weeks pulling bits of wire out of my skin :woohoo:
- wiredgeorge
17 Feb 2006 05:53
In my business, I use wire brushes on Dremmel tools constantly. You must keep them on the lowest speed ranges to keep them in one piece. I use about two brushes per every set of carburetors I clean as they are really the best way to polish the inside of the carburetor (venturi / slide). I do tend to get wire bits in my skin, clothes and shoes. If you want to REALLY get the rust, take the frame to a blast shop and let them sand blast it.
- fergyfer
17 Feb 2006 08:39
If I were doing a whole frame, I think a blast shop would be the best idea. But working on a small area that is hard to get to, I use a 1/4" piece of tubing, wrap duct tape around it until it meets, then back around it sticky side out. Then I unfold a new piece of steel wool and wrap it around the tubing nice and tight. Insert it into my variable speed drill and go at it. It works nicely. It's a pain to change out, but it works pretty good on the rust and paint removal. Depending on the grade of steel wool, it can polish the aluminum parts very well, like using the 0000 grade...
- ran429
- Master of FREE rides!
18 Feb 2006 01:35
aircraft paint stripper/remover (only at auto paint stores)& navel Jelly (hardware store) are your friends.
- godsjester71
18 Feb 2006 10:07
steell wrote:
Yeah, took me about 2 second to realize what was bouncing off my face. :laugh:
This is the grinding wheel on the left:
Post edited by: godsjester71, at: 2006/02/18 13:50
- godsjester71
18 Feb 2006 10:09
reborn650 wrote:
Thanks, I will try that for the non-rusted areas!
Post edited by: godsjester71, at: 2006/02/18 13:54
- godsjester71
18 Feb 2006 10:16
RomSpaceKnight wrote:
I'm just hitting the rusty areas, and roughing up the paint, then with as good of a rattle can paint job as I can. I'll go full media blast and powder coat in a couple years.
Here I have used the grind spool, some hand sanding at the bottom, but I still can't get into the corners. At he top, you can see how close I can get with the grinding spool. I'll try the low speed Dremmel/angled wire wheel here:
Post edited by: godsjester71, at: 2006/02/18 13:56
Post edited by: godsjester71, at: 2006/02/18 13:59
