KZ 650 Master Cylinder kaput?
  • seanof30306
  • seanof30306's Avatar Topic Author
Re: KZ 650 Master Cylinder kaput?
19 Sep 2008 06:07
#237751
civilengr3 wrote:
Here's the one I bought. Quite pleased with it.
tinyurl.com/4lvu5m
That's the one I was trying to post. Wonder why the url wouldn't work for me?
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
  • seanof30306
22 Sep 2008 17:06
#238240
Ok, I'm lost. My leaking master cylinder says "14mm" on the bottom, so it's for a single caliper setup.
I'd found this one on ebay:
tinyurl.com/4lvu5m
It's the one civlengr3 bought, and says he's pleased with, although he didn't say whether he had single or dual calipers.
It says it's for dual calipers, but it also says it has a 14mm bore. That would seem to be oxymoronic to me.
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
  • seanof30306
26 Sep 2008 02:24
#238716
Civilengr3 said he has one of those 14mm aftermarket master cylinders on his bike, and it works fine. Does anyone know whether he has single or dual calipers?
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
  • ddm1075
  • ddm1075's Avatar
23 Jan 2011 13:13
#424748
I've just been given a 1977 KZ650C Bobber and I plan to replace the handlebar controls with a pair off of a HD Sporster. My question is, would it be possible to use the HD 11/16 Master Cylinder on the stock brakes? I figure the large bore size would be able to handle the dual calipers on my bike, but I wasn't sure if there is anything else I should be mindful of.
Bobbed
1977 KZ650C
