can dirtbike forks be used on a raked bike?
- themachine
15 Sep 2008 14:47
i have a 2004 kx250 with no motor and really nice forks and triple trees with the weel and brakes and all.
i was curious, if i was to rake my bike out would these be safe to use on the road (with a steering stabilizer) and for dragracing (under 130mph)
i kno i know they'd look goofy on a kz1000, or would they.....
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- racer54
Re: can dirtbike forks be used on a raked bike?
15 Sep 2008 14:54
Don't know about those forks, but I know some guys use the front ends off KZ400 for this reason and they are going much faster then 160 mph! I would think the abuse those forks are designed for, they could handle the load, but not sure how the valving would work out though. How big diameter are they? That would say alot.
- themachine
15 Sep 2008 15:22
they are the big fat thick upside down forks with that gold coatin, i think theyd look awsome on a raked out bike.
- kano
- Not Another Bloody Limey!
15 Sep 2008 15:52
i have wondered about this too but went with a set of busa forks instead 4 me elr.
only prob i came up with not to use them was most dirt bikes dont run duel calipers on the front.
- PLUMMEN
15 Sep 2008 19:39
we used to run dirtbike/small streetbike frontends and triple trees years ago on dragbikes whe we couldnt afford the fancy italian stuff kosman was selling.i gave solomrus a frontend and wheel with disc brake from a kz400 for his turbo/dragbike
- oldkaws4ever
- Have no regrets...... You only live once.
15 Sep 2008 20:35
I heard the advantage is that you go from a 19 inch front tire to an 18 inch hence better handling right? Is the kz 400 front end a bolt on thing for a z1 900?
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- PLUMMEN
15 Sep 2008 21:05
its easier to get an 18" slick for the front and its lighter,i dont reccomend it for a bike you want to drive around town.
- RollingStock
15 Sep 2008 22:18
yes it can be done.. we have 2 choppers here at the shop that have dirtbike frontends.. i will being running a kx125 feontend on my kz750 chopper
73 z1900 street nitrous drag bike(powered but honda)
83 kz750 turbo street fighter project
- themachine
16 Sep 2008 10:27
anything you have to do to the spring pressure or valving as some mention, mines going on a heavy kz1000.
- Jack
16 Sep 2008 11:47
PLUMMEN wrote:
Yep, we use S2 & S3 or H1 front ends,been 156+ mph. Set up for 18" wheel and all you have to do to the S series stuff is change the stem to Z/KZ type.s
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- tachrev
- Rubber Side Goes Down
16 Sep 2008 12:51
Jack wrote:
Ever measure the weight difference between the two front ends?
PLUMMEN wrote:we used to run dirtbike/small streetbike frontends and triple trees years ago on dragbikes whe we couldnt afford the fancy italian stuff kosman was selling.i gave solomrus a frontend and wheel with disc brake from a kz400 for his turbo/dragbike
Build Thread
Build Thread
- Jack
17 Sep 2008 06:16
Never weighed 'em but the S2 & S3 2 stroke front ends are lighter than the H1.The H1 has the same diameter forks as a Z1 but the S stuff is smaller at 34mm.
79 KZ 1075 MKll
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
