gs swingarm conversion chain length?
  • dnestell
  • dnestell's Avatar Topic Author
13 Feb 2006 18:35
#23656
i am wondering if anyone with a gs swingarm on a 650 can help. i was wondering if a 114 link chain would be long enough with the gs swingarm.
Post edited by: dnestell, at: 2006/02/13 21:39
  • wireman
  • wireman's Avatar
Re: gs conversion conversion chain length?
13 Feb 2006 18:39
#23660
try sprocket specialist they have sprocket/chain chart that might help .;) goodluck,happy wrenching!
  • dnestell
13 Feb 2006 18:40
#23661
are there specific websites i should check?
  • baldy110
  • baldy110's Avatar
13 Feb 2006 18:42
#23663
I have a KZ650C with the GS1100 aluminum swingarm and I had to go to a 110 link chain. 114 links will be to long if you are using the stock sprockets.
kzrider.com/forum/viewthread.php?tid=11890
Post edited by: baldy110, at: 2006/02/13 21:44
  • dnestell
13 Feb 2006 18:56
#23666
can i get a 114 and cut it down to size? i think galaxian said to do that to a 120.
Post edited by: dnestell, at: 2006/02/13 21:58
  • wireman
  • wireman's Avatar
13 Feb 2006 19:03
#23669
try that sprocket specialist website theyre on the links just punch in the numbers on chart and hit optimise.
  • dnestell
13 Feb 2006 19:09
#23671
i tried it but i don't think it will give you modified lengths. the stock chain for the kz650c is 102 but the gs swingarm adds a few inches.
  • wireman
  • wireman's Avatar
13 Feb 2006 19:16
#23675
put in whatever the lengh is fro pivot to adjuster and the rest of your info and hit optimize,it will adjust the chain length for you.:whistle:
  • baldy110
  • baldy110's Avatar
13 Feb 2006 19:21
#23682
Yes taking out links will work.
  • dnestell
13 Feb 2006 19:27
#23685
  • baldy110
  • baldy110's Avatar
13 Feb 2006 19:45
#23700
Take it from someone who has been there and done that, 110 links.
  • steell
  • steell's Avatar
13 Feb 2006 20:59
#23718
Why mess around when baldy110 has already done what you want to do, and has given you the answer?
Yes you can easily shorten a chain, so if you have a 120 link chain just take off 10 links. But you can order a 110 link chain and save a few bucks.
