KZ1000P SwIngarm
- danB
KZ1000P SwIngarm
13 Feb 2006 09:08
Am looking at a KZ1000P Swingarm to mount in my 78 KZ650 - I know the 78 KZ1000 swingarms will fit - does anyone know if the 87-91 KZ1000P swingarm is the same width bearing-wise as the older 77-78 KZ1000s, and if there are any other differences I need to be worried about?
- wireman
Re: KZ1000P SwIngarm
13 Feb 2006 09:24
im trying to picture what a kz1000p series is,police bike?:whistle:
- danB
13 Feb 2006 10:04
Yes, it is the police bike. Here is the EBay item I am looking at, has a good picture
cgi.ebay.com/ebaymotors/KAWASAKI-POLICE-...QQrdZ1QQcmdZViewItem
- wireman
13 Feb 2006 10:31
that looks completely differant to me,im trying to chase down another aluminum swingarm for my 80 1000ltd,if i can find an aluminum one this stock steel one will be up for grabs its the same as 78 1000.:whistle:
- guitargeek
13 Feb 2006 11:16
I was considering one of these as well. I saw one on ebay and emailed the seller with questions about the dimensions of the swingarm but they couldn't be bothered to write me back with any answers.
How much longer is the 1000P swingarm than the stock KZ650/750 swingarm? What would we really be gaining? What about spacers and such?
Oh, and Wireman, check this out: cgi.ebay.com/ebaymotors/Kawasaki-Suzuki-...dZ1QQsspagenameZWDVW
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- wireman
13 Feb 2006 12:31
kind of corny looking with all that paint on.looks like gs1100e ill keep an eye on it ,im looking here locally also.thanks jim!
- danB
13 Feb 2006 12:31
The main advantage of the KZ1000P arm, if it is the same as a earlier KZ1000, would just be a inch or two of length and a little more beef over the KZ650 arm and an all stock look. Just rebuilding a 650 and looking for a KZ100 arm to put in - I have a KZ1000 rear disc wire wheel to put on the 650, so it goes better with a KZ1000 arm without having to modify it.
- wireman
13 Feb 2006 12:37
you wouldnt want to swap those wire wheels for a set of disc brake mags would ya?:whistle: my local connection is really begining to piss me off on the wheels he was suppose to order me 3 weeks ago!:whistle:
- danB
13 Feb 2006 15:01
wireman wrote:
sorry dude, wires are the only way for me
- wireman
13 Feb 2006 16:53
you and me both,i want talon hubs ,stainless spokes and some aluminum rims.it looks like i might have to settle for stock hubs,i dont have time to chase down differant brakes and everything else to fit new hubs.HELLO BUCHANANS!:whistle:
- danB
Re: KZ1000 vs KZ650 SwIngarm
16 Feb 2006 22:30
Well the EBay seller for the KZ1000P swingarm offered me a 77 KZ1000 arm instead, so I took that. Is going to go into a 78 KZ650 frame and would give me a little beefier swingarm and just about a 1 1/2 inch longer axle point. However, what I have found out so far on comparing them side by side, is that the KZ1000 arm is about .125 wider at the outsides of the bearing tube than the KZ650 arm and either the frame bushings or the arm will have to be trimmed to fit the arm into the KZ650 frame. Has anyone else done this swap and which side of the problem did you trim?
The other thing I noticed that surprised me, was that the inside of the KZ650 arm is actually wider at the front area than the KZ1000 arm, it looks like it is about 1/4 to 3.8 wider, so it looks like it will actually allow a wider tire on the KZ650 arm.
Just some findings in case anyone is interested in this swap. Have not decided if it is worth trimming the KZ1000 arm to fit yet or not
- Sandy
- Fly High,Tony
16 Feb 2006 22:49
Just a thought...what about the brake-stay arm?...same length,or will You have to mod that...or use the 1000P caliper as well? You might want to look into that one before You go and get all gung-ho on the install...
Or get some measurements,and have one made up?...:dry:
1977 KZ1000 A-1
