KZ1000 What front end?
- supercharged
03 Aug 2008 19:29
I'm looking to make an old style superbike with new style parts, so I figure I should ask those that know...
The base bike will be a KZ1000 and probably an LTD. I'm wanting a newer front end and thinking Gixxer 1000. Any input. I have been watch a few threads here, but searching for this topic didn't get me much.
Also doing a swingarm. Not sure where to go, but figure I would want to bring it out (extend) maybe 2-4", since I think the originals look a bit stout. Open to suggestions...
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport... eahhh not so good
- 1988 KZ1000 Police - 50K miles
- 1978 KZ1000 LTD - should be a quick project
- 2001 KZ1000 Police - 30K miles - chromed Sgt Bike GREAT SHAPE
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
- PLUMMEN
Re: KZ1000 What front end?
03 Aug 2008 20:01
what are you planning to do with the bike?a 4" over arm is going to cancel out any cornering advantages of newer frontend
- supercharged
03 Aug 2008 20:23
Looking for a superbike styled bike. Just for use as a weekend warrior.
I thought 4 might be pushing it...
Oh thinking of going 17" wheel on back. and may have a frame person adjust trail after conversion.
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
- zippy
03 Aug 2008 21:44
Might try Mcintosh for the swingarm. He modified mine for me. I had a 2" over arm and he lengthened it to an adjustable 10" over arm with new hardware. Cost me around $ 400. Well worth it and great workmanship,
Here is his web site.
www.mcintoshmachineandfabrication.com/Swingarms.htm
Also - here are some pics of my bike from another thread.You should be able to check out the swingarm from the pics.
Pics are toward the end of the thread.
kzrider.com/index.php?option=com_kunena&...mit=20&limitstart=20
- supercharged
03 Aug 2008 22:51
Zippy, thanks for the link.
I saw your bike. Drop me a line, I may know someone who wants to buy the bike. Brings back lots of memories... that Magnuson was powerful AND beastly looking;)
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
- StreetfighterKz
04 Aug 2008 04:36 - 04 Aug 2008 04:38
'Charged,
Are you wanting to keep cornering clearance or do you want the long and low look? Pretty much any newer front end except some of the Zx9R's and a few years for the Gsxr1100 are going to be shorter than you stock forks. Running a 17" rim compared to the stock 19" will also make the drop even worse. You can get around this by making stepped yokes for the steering but that can become pricey.
I've did a newer front end swap. Look here .
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
Last edit: 04 Aug 2008 04:38 by StreetfighterKz.
- kzr750r1
04 Aug 2008 06:48
For the updated USD the ZX9 legs are the longest OEM available. I think it is the '94 that has the provisions for six piston calipers.
As for the swingarm a Suzuki TL1000 swing arms are some of the shorter late models out there...
The issue is exacerbated by placing 17" wheels but the advantages are great as you can then use the new radial rubber.
Take your time... I sure have... Just have the swing arm at the moment.
If your going to mess with suspension geometry make sure what your goals are.
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
- supercharged
04 Aug 2008 09:08
Good point. No, I'm not looking to drop the front, my goal is an old style superbike look with new components. I like to lowered dragbike look, but that is not my goal here.
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
- StreetfighterKz
04 Aug 2008 12:24
What about a ZRX or Bandit front end? They got the old skool look with new school innards. I just don't know the length of either of them.
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- kzr750r1
04 Aug 2008 12:55
I just had this conversation with my mechanic. I'm in the same boat. The origional goal was to go all new school (USD Front End) components. Not so much any more. Seeing the A-Magic rece bike running on traditional legs made me think... "Man, why not just find a ZRX front end"....
Have not placed a measuring tape on a ZRX yet, not sure of the length either.... But on the other hand having some extended fork tubes (if needed) is more liely than finding them for a USD leg.
Big concern for me is not lowering the bike. Been there with mini trucks and grinding underbelly hard parts is not somthing I aspire to do much these days.
Ive already touched the header with the existing suspension when riding. Hate to see how my pipe will turn out if it's lower to the ground.
- BigBlockT
04 Aug 2008 13:30
the only advice I can give is address the chain to frame , tire clearance issue well before you paint or powder coat the frame,I made this mistake well to late asfar as the modern components check my ride out in the projects, its still a work in progress. Good Luck.
- Calhoun
- Hayabusa= I ride to the strip club in flip flops
04 Aug 2008 14:04
80 IT175, 84 XL200, XT250, 95 ST1100 96 xr650l (30k miles),kz1000, KX250 97'
Last and most important 93 KX500.
