Rear wheel shock damper - Glue it?
- JMKZHI
05 Jun 2008 06:23 - 07 Oct 2009 07:05
While servicing the rear wheel, I removed the shock damper from the hub to clean it. Is it supposed to be re-glued in place? Mine appears to have been glued at the factory.
Edit: it's a one piece cush drive damper in good condition & fits snug.
Last edit: 07 Oct 2009 07:05 by JMKZHI.
- rstnick
Re: Rear wheel shock damper - Glue it?
05 Jun 2008 06:26
Are you refering to the large round rubber damper in the hub? Cush (crush ?) drive I believe it's called.
The two I've had open the damper was loose in there. Can't go anywhere when it's all together.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- JMKZHI
Re: .
05 Jun 2008 06:53 - 07 Oct 2009 06:49
The Kaw diagrams list it as a rear hub shock damper - I guess folks refer to it as the cush drive. It's the big rubber thing, about 8" in diameter, looks maybe kinda like a ... what does that thing look like? It's a weird shape. JMK.
Last edit: 07 Oct 2009 06:49 by JMKZHI.
- Sandy
- Fly High,Tony
05 Jun 2008 08:21
rstnick wrote:
That's true,but I'm thinking that maybe someone has been in there,and has applied some urethane to take up some slop in the dampners.
Some of them are a 1-piece,where others are individual pieces(6).
There are posts(more likely in the archives)about this,and what members have done to build up the rubber when the old ones get worn,using urethane-based products.
If there's only "Spots" of glue,then it COULD be factory,to hold the dampner in place,during assembly.
1977 KZ1000 A-1
- Bluemeanie
06 Jun 2008 06:11
JMKZHI wrote:
A big black flower??
- Sandy
- Fly High,Tony
06 Jun 2008 07:09
I LIKE it John...a "Big black flower"....works for me!:laugh:
1977 KZ1000 A-1
- JMKZHI
Re: .
06 Jun 2008 07:12 - 07 Oct 2009 07:01
The shock damper (cush drive) on my 81 650-CSR is a one piece unit in good condition & fits snug.
Last edit: 07 Oct 2009 07:01 by JMKZHI.
- JMKZHI
07 Oct 2009 07:06 - 07 Oct 2009 07:07
Bump. Still wondering if others glue theirs in place. :blush:
Last edit: 07 Oct 2009 07:07 by JMKZHI.
- timebomb33
07 Oct 2009 07:22
no need to but you could if you want, wont hurt anything
I THINK MY POWERBAND BROKE
- JMKZHI
07 Oct 2009 07:57
Okay, thanks. I didn't glue it then. I guess I won't do it this time either.
There was a shock dampe article by jtmcculloch (fairly sure) around here somewhere, but I can't seem to find it. It was more of a repair how-to, though.
- OKC_Kent
07 Oct 2009 14:21
I have put some clear Auto-Goop on my cush damper to take up a little slop. After 4 years it's back.
The previous owner of your bike probably did the same thing.
Cashion, OK
78 KZ650 B2 85,000+ miles
- JMKZHI
07 Oct 2009 15:19 - 07 Oct 2009 15:20
I am the previous owner.
The damper was lightly glued at the factory.
As stated, it's in good condition & fits snug.
I'm not going to bother glueing it or anything.
Last edit: 07 Oct 2009 15:20 by JMKZHI.
