Rake Services
- Lorcan
- Speed Loony
Re: Rake Services
05 Dec 2005 10:28
Just bear in mind while you a raking your frame that the whole of the street-tyre drag world is doing the opposite.
Short forks, reduced offset yokes (triples) and small front wheels (16") are IN...raking is OUT!
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- solomrus
Re: Rake Services
05 Dec 2005 14:14
lorcan,
why not buck the trend and do something no one else is doing?
just kidding man. i understand what you are saying. people do things for a reason, and *everyone* wouldn't be doing it if there weren't some merit.
i think there is a tradeoff whichever way you go. if the bike is track only, then those tradeoffs tend to cancel each other out.
if i were going to ride my track bike on the street, then i would build things differently.
--r
--r
198o kz1ooo Bravo Four
- wireguy
Re: Rake Services
07 Dec 2005 20:54
i think part of the reason those guys are putting 12-24"swingarms on those sportbikes is because it would be so complicated to rake a newer style aluminum frame compared to older equiptment!has anybody seen a newer raked frame?
- Lorcan
- Speed Loony
Re: Rake Services
08 Dec 2005 03:54
That's not the reason, they use a long swingarm to keep the weight as far forward as possible. Raking effectively moves the weight back, which is bad news in a restricted wheelbase class.
760cc - 8.69@162mph
- kawtoy
Re: Rake Services
08 Dec 2005 10:15
Raking and extended forks also greatly reduces your steering control. It will be harder to turn when you want and harder to stop it from turning when you don't. A little rake won't hurt as long as you are not planning to take to Deal's Gap or similar.
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
- wireguy
Re: Rake Services
08 Dec 2005 13:19
i think we are talking more of a drag only bike in this situation,no killer turns involved to cause problems with the raked front end.i had a gs1100 suzuki once when i was young and dumb anyway it was a half mile long and sat up like a 4x4 truck.i tried the usual stuff that helps on kaws lowered the front and rear but suzukis are so long and have a lot of rake right out of the box so it was really stable in a straight line,but a 305 honda could tear it up in a curve on the interstate!i finally jacked the rear up about 2" andleft the front lowered which helped the cornering out greatly!it just depends on what the bike is used for.
- solomrus
Re: Rake Services
08 Dec 2005 19:39
my bike is going to be track only. not building for a class of any sort. i want it to launch straight, be stable at speed, and stay together.
i only want to go and run numbers for myself. just to see if i can do it. a personal goal, if you would. i have the power plant, and it really belongs in a track bike.
i was talking with a local guy who races today, wire, you might know him. jim t. down at c&c cycles. anyways, his info is 6-7 degrees over stock rake, lower the forks or no, just get the bike level front to rear. i'm gonna run a fairly small tire, and i have the facilities to back-half it, so i will build for more in the future.
so, yeah, that's the plan.
wire, when you raised the rear end of that zook, you shortened the wheelbase some, and the rake/trail. that would explain the benefit to your steering.
lorcan, sounds like you do a bit of racing. what type of bike/class do you run in?
i'll be building another bike once i have this drag project done. i'll have a second frame that i plan on updating with newer suspension, running a 1200 n/a motor, and generally having fun with.
--r
--r
- wireguy
Re: Rake Services
10 Dec 2005 20:15
wheres that phonecall?933-1503
Post edited by: wireguy, at: 2005/12/10 23:16
- solomrus
Re: Rake Services
11 Dec 2005 08:04
busy this weekend. probably ring you middle of this week.
--r
--r
