caliper question
- vach
caliper question
04 Apr 2008 12:53
i'm looking to put a dual disc setup on the front of my bike. i have everything but the caliper. is there a right and left handed caliper? or are they universal for both sides?
thanks,
vach
thanks,
vach
1979 kz650 B. Chicago, Illinois
- 77_650B1
Re: caliper question
04 Apr 2008 12:58
Theres a left and right handed one. Just make sure you're looking at yours when you look at a pic of the one you're buying. Should be a mirror image.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- Sandy
- Fly High,Tony
04 Apr 2008 13:09
Not sure about the 650 set-up,but on my 1000,I used 2 identical calipers,but had to flip one of the brackets around...pretty straight-forward,as far as the caliper mount went.Had to make up 2 new solid sections of brake-line though,because moving the calipers to the rear of the forks,changed the distance and location,so the old lines were unusable.
1977 KZ1000 A-1
- vach
04 Apr 2008 14:28
will 2 calipers from an 80 kz1000 fit? they look the same, kawasaki say's some 900's fit. are all the mounting bolt hole the same. what i'm saing is if i cant find an exact match to my caliper via the cross reference sheet at kaw. will 2 other calipers fit. most of the brake discs are the same for my bike.
thanks
thanks
- Sandy
- Fly High,Tony
04 Apr 2008 14:46
Lemme just check with my cross ref programs and see what comes up...
1977 KZ1000 A-1
- Sandy
- Fly High,Tony
04 Apr 2008 14:59
Hmmm...nothings jivin here...different part #'s
I think the biggest concern is that the mounting points be the same...got any specs on them?
1977 KZ1000 A-1
- vach
04 Apr 2008 19:08
unfortunately no, the bike is about 1hr away from me. i did a search at kaw and these came up for the front discs. 41080-005 Model (22):
H1 (Mach III) (1969)
H1-C (1972)
H1-D (1973)
H1-E (1974)
H1-F (1975)
KH500-A8 (1976)
KZ1000-A1 (KZ1000) (1977)
KZ1000-A2 (KZ1000) (1978)
KZ1000-A2A (KZ1000) (1978)
KZ1000-A3 (KZ1000) (1979)
KZ1000-A3A (KZ1000) (1979)
KZ1000-A4 (KZ1000) (1980)
KZ650-B1 (1977)
KZ650-B2 (1978)
KZ650-B2A (1978)
KZ650-B3 (1979)
KZ750-B1 (1976)
KZ750-B2 (1977)
KZ750-B3 (1978)
KZ750-B4 (1979)
KZ900-A4 (1976)
KZ900-A5 (1977)
and these came up for the calipers 43041-030
Model (22):
H1-C (1972)
H1-D (1973)
H1-E (1974)
H1-F (1975)
KH400-A3 (1976)
KH400-A4 (1977)
KH400-A5 (1978)
KH500-A8 (1976)
KZ650-B1 (1977)
KZ650-B2 (1978)
KZ650-B2A (1978)
KZ650-B3 (1979)
KZ750-B1 (1976)
KZ750-B2 (1977)
KZ750-B3 (1978)
KZ750-B4 (1979)
KZ900-A4 (1976)
KZ900-A5 (1977)
KZ900-B1 (LTD) (1976)
S3 (Mach II) (1974)
S3-A (Mach II) (1975)
if the discs are the same my guess would be the mounting braket space. they look the same but there's no way to tell unless i measure. however this site www.redlinecycle.com/Brake%20-%20Caliper%20I.D..html
say's the early style calipers from the kz900 and kz1000 are the same. the late model style that i have wih the banjo fitting say's there is really no difference other than the fitting. thanks and i wouldappreciate any more feedback.
thanks again, vach
H1-C (1972)
H1-D (1973)
H1-E (1974)
H1-F (1975)
KH500-A8 (1976)
KZ650-B1 (1977)
KZ650-B2 (1978)
KZ650-B2A (1978)
KZ650-B3 (1979)
KZ750-B1 (1976)
KZ750-B2 (1977)
KZ750-B3 (1978)
KZ750-B4 (1979)
KZ900-A4 (1976)
KZ900-A5 (1977)
Model (22):
H1-C (1972)
H1-D (1973)
H1-E (1974)
H1-F (1975)
KH400-A3 (1976)
KH400-A4 (1977)
KH400-A5 (1978)
KH500-A8 (1976)
KZ650-B1 (1977)
KZ650-B2 (1978)
KZ650-B2A (1978)
KZ650-B3 (1979)
KZ750-B1 (1976)
KZ750-B2 (1977)
KZ750-B3 (1978)
KZ750-B4 (1979)
KZ900-A4 (1976)
KZ900-A5 (1977)
S3 (Mach II) (1974)
thanks again, vach
- steell
04 Apr 2008 19:20 - 04 Apr 2008 19:23
If your 80 KZ650B uses four bolt rotors, then I'd be almost willing to bet money that KZ1000 calipers will fit, along with 83-85 GPz750, and 76-80 KZ750 twins.
I think there is a real good possibility that all KZ and GPz calipers up through 85 will work.
On my 750 twins I have installed 79 KZ650SR calipers, 78 KZ1000 calipers, and 83 GPz750, calipers, and all bolted on.
Currently I have 83 GPz750 calipers, 79 KZ1000 drilled rotors, and a 95 GPz1100 master cylinder, and I am "real" happy with the way it stops (except the once when it didn't). Best brakes I have ever had on a twin.
The GPz750 had a 10" rotor, the 79 KZ1000 had 12" rotors, that extra leverage helps out a "lot". My 79 KZ750 twin will easily out brake GPzInfested's 750 Turbo
I wish it would accelerate as fast as the 750 Turbo
You did have to post that while I was still typing didn't you :laugh:
Last edit: 04 Apr 2008 19:23 by steell.
- vach
04 Apr 2008 19:42 - 04 Apr 2008 19:43
thanks steel.. i'm not sure what you mean about the 4 bolt calipers.. do you have a pic? here's a pic of what looks just like the caliper on my bike except this pic is from a kz1000.
oh, btw i have a 79 b3
Last edit: 04 Apr 2008 19:43 by vach.
- PLUMMEN
04 Apr 2008 21:44
the rotors are held on hub with 4 bolts,i think the pistons in the dual disc calipers might be smaller since there are 2 calipers doing work instead of 1B)
- steell
05 Apr 2008 04:58If your 80 KZ650B uses four bolt rotors, then I'd be almost willing to bet money that KZ1000 calipers will fit, along with 83-85 GPz750, and 76-80 KZ750 twins.
Four bolt rotors
Most calipers (if not all) are held on by two bolts.
You generally can't use 12" rotors on a bike that originally had 10" rotors because the caliper is mounted lower on the fork leg, the caliper will hit the rotor.
- Sandy
- Fly High,Tony
05 Apr 2008 12:03
steell wrote:
[/quote]
Four bolt rotors
[/quote]
Don't get that confused with "Calipers"
A pic of a 6-bolt ROTOR...
[/quote]
Four bolt rotors
[/quote]
1977 KZ1000 A-1
