kz900 alloys wheels?
- kzmason
17 Mar 2008 08:15 - 17 Mar 2008 08:16
Did any of the 900's have alloys wheels? If so, can they swap out to the 1000.
Last edit: 17 Mar 2008 08:16 by kzmason.
- StreetfighterKz
Re: kz900 alloys wheels?
17 Mar 2008 08:47
Yes, the 1976 900 LTD has cast rims and no they are not a direct swap into a 1000. I know the spoked wheels on the '73-76 900's are drum brake in the rear and I believe the '76 LTD cast rim is as well.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- Mcdroid
- Gone Kwackers
17 Mar 2008 09:49
As has been mentioned by Doug, the KZ900B (LTD) had the desireable Morris wheels, but they did have a disk on the rear wheel...it was the only 900 w/a rear disk brake.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- steell
17 Mar 2008 10:19
Kawasaki dealers sold a Morris Mag kit for the 750B twin back in 79, and there are a few of them around, I bought a NOS set on eBay last year.
And they will bolt right on the 1000's.
16" rear and 19" front.
- StreetfighterKz
17 Mar 2008 12:07
Mcdroid wrote:
I somehow thought they might have but couldn't find any solid supporting evidence in the Kz900 gallery.
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- 76 LTD
17 Mar 2008 13:02 - 17 Mar 2008 13:07
My local Kaw dealer has a Kz900 with morris mags and drum brakes the wheels were installed by the dealer.they did make tham i saw a set on ebay a while back but i think they were lesters.the 900 LTD was the first and only 900 to leave the factory with disk on rear.they were also the first and only LTD 900.they were only produced 1/2 year.LTD rotors have different offset than regular Kz rotors.I think the calipers are different also.
Last edit: 17 Mar 2008 13:07 by 76 LTD.
- Locozuna
17 Mar 2008 16:03
???:ohmy: I swapped out drilled rotors to my stock 76 900 LTD with no offset difference. The only difference I have seen in rotors are that the dual disk rotors are thinner by a couple MM than single disk rotors. Lesters are aftermarket I have a set on my 77 650 with drum rear. But they were available for the 900 and a lot of other bikes before that. 76 900 LTD was made in 2 builds in 76. 3 manufacturers are used in making the mags for the LTD series. In 76 it was Morris, then a mfg whose name escapes me right now and then Kawasaki made them themselves. Morris are the original manufacturers and are the more desirable to collectors and restorers.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- rstnick
17 Mar 2008 18:47
Is the second manufacturer Enkel? Or is that what the last series were?
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- kzmason
- OldSchoolHr
- Kawasaki z900a4 1976 Croatia, Europe
17 Mar 2008 23:20 - 17 Mar 2008 23:52
Down there is picture of my z900 with kz1000 alloy wheels and the other picture
is with kz750b (twin) spoke wheels.
In both case you must only upgrade your rear brake to the disc.
My Gallery -
www.wix.com/limit2/z900
Last edit: 17 Mar 2008 23:52 by OldSchoolHr.
- OldSchoolHr
18 Mar 2008 00:02
I just saw that you have kz1000 so I dont know what is your question here.
Can you put a kz900 rear wheel with drum brake on kz1000!?
My Gallery -
- steell
18 Mar 2008 04:52
kzmason, that looks like a Morris Mag in that picture, should be marked with a circle with a stylized M inside the circle on the edge of the rim.
