Steering Stem Bearings ???
- btchalice
Re: Steering Stem Bearings ???
24 Feb 2008 22:42
i just got mine in from z1 get the 1 with the seals for 36
extra money for less parts confused me
they shipped it fast and they fit perfect
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- 2M4Dale
25 Feb 2008 02:41
OK btchalice, I'll take your word for it ... I'll order the cheaper set. Probrably order 'em on Wednesday.
Hello from Sunny Mansfield, Ohio
1980 KZ750H1 LTD
1981 KZ750H2 LTD
1980 KZ750H1 LTD
1981 KZ750H2 LTD
- Shoe48
- Live each day as it is your last
25 Feb 2008 05:21
Z1 has always been dead on right ,, go with what is known
- CoreyClough
- GPz550 Addiction
25 Feb 2008 05:42
All Balls makes the bearings and includes the seals too. 28 years and no servicing? :blink: Shame on you!!! I bet they fall apart when you remove them. I've replaced, and upgraded, the races and bearings on both wheels and steering head with All Balls. Great fit, and reasonably priced. I'd never go back to the ball-bearing style. Peace of mind.
'85 GPz550(ZX550-A2)
- Locozuna
25 Feb 2008 05:48
I have replaced the bearings on 4 bikes. All had 25,000+ on the clocks. 2 of them had visible bearing damage. Only 1 had damage you could feel with the front end assembled. It was like turning a ratchet with the selector between left and right. Now my rule of thumb is 15-20K and you're gonna get new bearings and I go with tapered roller. Increasing the surface from ball to roller just makes sense. When done it is "like butter!" after.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- 2M4Dale
29 Feb 2008 18:32
New bearings arrive on Monday ... can't wait !!! once these things are installed I can begin reassembly of my bike !!!!!!!!!!!
1980 KZ750H1 LTD
1981 KZ750H2 LTD
1980 KZ750H1 LTD
1981 KZ750H2 LTD
- KZ250LTD
Last edit: 20 Dec 2011 04:00 by KZ250LTD.
- twinkyrider
01 Mar 2008 05:29
I was going to just relube the stock stem ball bearings because it was smooth. However, after I jacked the bike (KZ1000) up off the ground it was still smooth until I pulled the fork tubes out to rebuild then I felt the detents. Talked to Jeff @ Z1 and now have a new set of "All Balls" roller bearings w/ seals, $36. It was a pretty easy job too!
78 kz1000A
Fond du Lac,WI
Fond du Lac,WI
- 2M4Dale
08 Mar 2008 08:07
Finally ... taper roller bearings installed. Piece of cake. Feels like butta !!!! I'm glad I decided on this type bearings .... thanks guys
Post edited by: 2M4Dale, at: 2008/03/08 11:08
1980 KZ750H1 LTD
1981 KZ750H2 LTD
1980 KZ750H1 LTD
1981 KZ750H2 LTD
