leaning tower of Kz1000?
  • duncan
  • duncan's Avatar
Re: leaning tower of Kz1000?
22 Jan 2006 11:54
#19271
i don't know if this helps. my bike is a 1979 kz1000 LTD. the side stand is 10 3/8" long from the center of the mounting bolt to the far end of the stand, and sits 2" out from the swingarm (inside edge to inside edge). hope the pic works:
  • kwakagoose
  • kwakagoose's Avatar
22 Jan 2006 13:50
#19295
After looking at one of my parts bikes you do have a ltd kick stand on that bike.
  • kwakagoose
22 Jan 2006 13:53
#19296
Post edited by: kwakagoose, at: 2006/01/22 18:21
  • kwakagoose
22 Jan 2006 14:01
#19298
Here's my goose Kz1000 kick stand.
  • kwakagoose
22 Jan 2006 14:21
#19303
Here's a rough pic of the front bracket. I'll get some better photos this week outside in the sunlight
  • kwakagoose
22 Jan 2006 14:22
#19304
  • kwakagoose
22 Jan 2006 14:22
#19305
  • kwakagoose
22 Jan 2006 14:24
#19308
Tailpiece brackets
  • MkII
  • MkII's Avatar Topic Author
22 Jan 2006 17:58
#19340
appreciate the pics Goose....my stand is 11.5" from mount o/c to the tip and when retracted it is alot further out than 2" it's almost 4" at the tip. It looks like the wrong stand, it's bent, and the mount looks bent also. I think with the correct stand, a torch, and a small mallet, I can correct it.
1977A1 current project: 1075, Web cams, VM29's Cavanaugh massaged head, Z1 crank
1979A3A Parked in 1986 left in shed
Phx,Az
  • Snakebyte
  • Snakebyte's Avatar
25 Jan 2006 01:39
#19796
Is the pivot bolt loose or worn out. that will cause it to lean. I just put a piece of wood under mine for for now till I can fix it, or fall, what ever happens first,:P ...... I was just kidding about the fall thing I would never let it hit the ground.
