79 1000/99 zrx parts swap
- StreetfighterKz
Re: 79 1000/99 zrx parts swap
12 Dec 2007 08:16
Bad Kaw wrote:
I don't have pics but I can get them for you. Any particular info? Remember I'm also doing a swingarm swap on my 900 using a 91 Gsxr750 arm so if any info from that will help you let me know.
Later, Doug
Galaxian and 'fighterKZ,
Do you have any pics of the swingarm stuff you're talking about? I'm in the middle of *ahem* several swing-arm mods and you're info (pics too?:blush: ) would be greatly appreciated.
Thanks,
-KR
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- galaxian
12 Dec 2007 08:58
I will snap some off tonight if i get a change and post them. The garage is in winter mode meaning its a storage bin at the moment. So i may have furniture pictures in there as well;)
1977 KZ1000A1, 1979 KZ650 C3
- Bad Kaw
- Flying Squirell
12 Dec 2007 12:00
StreetfighterKz wrote:
Hey, thanks Doug! Yeah, basically any problems or modifications that you made and (as you indicated with the '91 gixxer 750 arm) what year and model of part you used. I appreciate any pics and descriptions you can give.
THANKS again!
-KR
Post edited by: Bad Kaw, at: 2007/12/12 15:02
Later, Doug
THANKS again!
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
70 Kawasaki KV75
- Bad Kaw
- Flying Squirell
12 Dec 2007 12:03
galaxian wrote:
I appreciate it! Yeah, my garage is in the same mode, so I get it! THANKS again!
-KR
-KR
78 Kawasaki Z1R
70 Kawasaki KV75
70 Kawasaki KV75
- tk11b40
12 Dec 2007 20:05
OK O
I have a gsxr 600 swingarm that I started to use before I bought the ZRX swingarm.
It would be easier to put the gsxr swingarm on. I turned it up side down, and ground some material away from the outer diameter of the sleeve housing the bearings. I did that on one side, so the swingarm would slide into the 2mm narrower KZ frame. Then sawed off the single (mono) shock mount. It slips right in no frame modifications.
I still have that swing arm. I can post a foto.
So, the ZRX swingarm is possible, but the gsxr is eaassssie. I even photo'd kind of a comparison shot.
This one is a 97 GSXR 600. You can buy them cheap. The ZRX swing arm if you have one is worth more cash.
They are approx the same width. You would need to mount some shock mounts the the GSXR swinger, but the ZRX if you want to do right, you gotta move the mounts anyway.
Suzuki GSXR 750 slabside
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- tk11b40
12 Dec 2007 20:10
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- tk11b40
12 Dec 2007 20:12
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- Bad Kaw
- Flying Squirell
13 Dec 2007 11:28
Very, very cool. The gixxer arm looks pretty good, too. I've got several arms to consider so I appreciate you posting and all the info you're giving.
-KR
-KR
78 Kawasaki Z1R
70 Kawasaki KV75
70 Kawasaki KV75
- xschop
22 Feb 2008 13:24
Hi, I put a triumph st single sided swingarm on one of my chops and have had many requests to do a swingarm for the XS11 yamaha. One question. What is the shock spacing measurement inside to inside on the zrx11 swingarm. I admire your work BTW....
- Bad Kaw
- Flying Squirell
22 Feb 2008 18:00
xschop: the XS1100 is a shaft-drive bike the last time I checked...???
78 Kawasaki Z1R
70 Kawasaki KV75
70 Kawasaki KV75
- xschop
24 Feb 2008 06:16
WAS a shaftdrive. I designed a bolt-on conversion and now looking for the perfect swingarm to use in the kit for others.....So I need to know this shock Inside distance, so far I can make an 04-06 R1 swingarm work, but will have to machine shock mounts and weld....the kit would be expensive then....thanks for any help...chop
- xschop
24 Feb 2008 06:19Please Log in or Create an account to join the conversation.
