offset rear sprocket
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: offset rear sprocket
09 Jan 2008 14:28
#188458
Ironnads. just a heads up hear, u may have done this allready. if u are using a swing arm that is not from this frame u should check the alignment. make sure the back wheel is in line whith the front wheel.the rear wheel is not allways centered in the swing arm but should be true to the front wheel. this is not imparitive but will give u the best handling and is the best place to start.
im not sure we are all getting what u are saying because u are not useing a kz arm and wheel. a pic is worth a thousand words.B)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
