what to do with turn signals
- bubba_d
18 Aug 2007 21:23
changed from stock bars to superbike bars. problem no room for turn signals. so i cut them off. no wish i had some. cant mount oe signals they dont fit. any ideas?
1977 kz1000.
- brich
Re: what to do with turn signals
18 Aug 2007 21:46
Not sure if this is your style or if they will work on your bars but ....
www.americanclassix.com/kawa_accessorieslight.html
1975 Z1 900, 1075 wiesco kit, web cams, smooth bores, dyna ignition, denco pipe, lester mags, wicked bad rotors, custom gauge face plates .. not much stock left.
- bubba_d
18 Aug 2007 21:49
that would work however i dont really like the idea. thanks any way
1977 kz1000.
- FloridaBiker
19 Aug 2007 04:05
Brackets about $8 from Z1 Enterprises
www.z1enterprises.com/detail.aspx?ID=431
Lights about $20 any cycle shop
Post edited by: FloridaBiker, at: 2007/08/19 07:08
- FloridaBiker
19 Aug 2007 04:09Please Log in or Create an account to join the conversation.
- 810gpz750
19 Aug 2007 07:22
bubba_d wrote:
here is an idea take all the signals off and use hand signals. how often do you really use them? in tx if you have signals they have too work but you can take them all off still legal. just an idea:evil:
- PLUMMEN
19 Aug 2007 10:38
they are usually the 1st victim to get the ax when i do a bike,but how about just mounting them through the headlight bucket mounting holes like millions of kzs since the beginning ?
- bubba_d
20 Aug 2007 23:13
thought about mounting them through the headlight bucket but how???
1977 kz1000.
- PLUMMEN
21 Aug 2007 01:07
what part of omaha are you in?i could probably scrounge up some stock kz style turn signals for you.
- FloridaBiker
21 Aug 2007 03:08
bubba_d wrote:
Use spacers and washers as necessary
Replace the bolt that holds the 'headlight to the fork bracket' with the turn signal bolt. (That is the main bolt that is part of the turn signal).thought about mounting them through the headlight bucket but how???
- bubba_d
21 Aug 2007 18:45
im in north omaha plummen. if if you got em. ill take em.
1977 kz1000.
- PLUMMEN
21 Aug 2007 18:58
give me a few days,ill pm you towards the weekend and bring em to ya;)
