1977 KZ650 Custom, need tire suggestions please
- rstnick
Re: 1977 KZ650 Custom, need tire suggestions please
01 Jun 2007 18:48
I have Bridgestone Spitfires front and back. I'm also using a 130 on the back, but did not have any rubbing on the plastic chain guard. I have switched back and forth betwwen the plastic guard and a chrome steel one, but just for cosmetic reasons, and both fit with clearance.
It will be my third season with the Bridgestones, and find them to be a good overall tire.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- RonKZ650
01 Jun 2007 20:47
650ed wrote:
Ed, That's pretty funny because the exact same thing happened to me on my KZ1000MKII, I slotted the guard to allow the tire to run then eventually the guard sucked right into the wheel. Thankfully still back in the days parts were available and $40 or so I was back stock and smarter not to cut into the plastic guard. One thing is certain though, the plastic chainguard is one great working piece of work. It keeps 97% of the crap off your back and the rest of the bike, unlike the alternative chrome guards do normally.
RonKZ650,
Way back when I switched to a Michelin 130 on the rear of my '77 KZ650C1, but it rubbed big time. Being the ingenious engineer that I was at the time, I simply cut out a portion out of the plastic chain guard and like magic, no more rub. A few months later the summer heat and some unknown stresses caused the plastic chain guard to warp at my idiotic modification and the whole chain guard was sucked into the rear wheel on a curvy road. Let me tell you, it was a lot different than baseball cards in bicycle spokes! I didn't wreck, but it scared the daylights out of me. After discarding the ruined chain guard I replaced it with a chrome aftermarket unit that doesn't rub. Ed
- anarki650
01 Jun 2007 21:52
Man, am I glad I didn't cut into my plastic guard when I put the 130/90 on! It looked like it was going to rub right at first when I mounted it up and my first thought was to cut a notch out of the guard but instead I took a second look at making sure my rear wheel was centered (it was off just a tad) and when I got it squared away the chain guard cleared with just enough room to be comfortable.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Omaha NE
- OKC_Kent
02 Jun 2007 06:14
I put a 120/80 Cheng-Shin Hi-Maxx on the rear. It has 13,500 miles and I should have replaced it at 12,000, but I will soon. It is an inexpensive tire, but has worked well for me, commuting and occasional highway use. I installed a new tube back then and don't see why it won't be good for another tire. Fits and looks good, it doesn't rub the chain guard either, I have the plastic one. Oh, make sure the inner front of the chain guard fits between the two metal tabs on the swing arm, or the guard will twist and rub the tire.
Ron,
is a 4.00-18 tire a 100% profile? 4.00" converts to 101mm, so will a 4.00-18 be a 101/100 (if they made such a tire)?
Ron,
Cashion, OK
78 KZ650 B2 85,000+ miles
- Biquetoast
- King Jeremy The Wicked
02 Jun 2007 06:22
650ed wrote:
That sucks. I cut a small piece out of mine on one of my 750s for my 120, that I ended up not needing to do anyway. It looked like it was rubbing before final alignment. Arg. I think for a 130 it would definitely have needed to be removed... It's been fine for about 7000 miles or so... Keeping my fingers crossed......Being the ingenious engineer that I was at the time, I simply cut out a portion out of the plastic chain guard and like magic, no more rub. A few months later the summer heat and some unknown stresses caused the plastic chain guard to warp at my idiotic modification and the whole chain guard was sucked into the rear wheel on a curvy road....
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- kzwolfsr
02 Jun 2007 07:12
I am so lucky to have a SR. They fit a 130 stock.
Original man of the Caribbean
02 Jun 2007 08:49
OKC_Kent wrote:
Good advice. Also applies to Z-1. And the tabs are easy to overlook when reinstalling chain guard following chain replacement, etc.
... make sure the inner front of the chain guard fits between the two metal tabs on the swing arm, or the guard will twist and rub the tire....
