REAR MAG WHEEL /SPOKE WHEEL SWAP
  • otakar
  • otakar's Avatar
Re: REAR MAG WHEEL /SPOKE WHEEL SWAP
26 Apr 2010 18:00
#363390
I did it with no problem. You may or may not have to replace the bearings depending on the wheel you get. Follow this link. By GPZ project started out as a 81CSR.
kzrider.com/index.php?option=com_kunena&...w&catid=11&id=169462
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • ramgoat
  • ramgoat's Avatar
26 Apr 2010 18:15
#363398
that sure is a nice bike but do i have to change swing arm and forks thanks jason
  • otakar
  • otakar's Avatar
26 Apr 2010 18:20
#363400
No you do not. That will actually make things harder if you do.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • ramgoat
  • ramgoat's Avatar
26 Apr 2010 18:41
#363410
any idea on year mag that would work thanks jason
  • otakar
  • otakar's Avatar
26 Apr 2010 18:45
#363411
There are quite a few that will. anything from a 750, 1000, 1100 chain drive from 1978 to 1983. as I mentioned before, you might have to change the bearings. If you get wheels from 81/82 LTD they should be a drop in swap.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • ramgoat
  • ramgoat's Avatar
26 Apr 2010 19:27
#363424
thanks
  • ramgoat
  • ramgoat's Avatar
12 Jun 2010 15:04
#375300
still no luck do u have wheels for sale? tanks jason
  • ramgoat
  • ramgoat's Avatar
12 Jun 2010 15:06
#375302
is there a way to chat in private about this?Thanks Jason
  • otakar
  • otakar's Avatar
12 Jun 2010 15:09
#375305
If you are communicating with me, I sent you a PM.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • TexasKZ
  • TexasKZ's Avatar
12 Jun 2010 15:43
#375314
Use the little pm button in the left column.
