looking at a kz1000 ltd (what's the significance of ltd?)
- griffin_
Anything I should known before checking it out?
The stumbling at higher rpms he describes sounds like a fuel flow issue (clogged jets most likely?)
I posted the ad below
Thanks for any help
1977 Kawasaki KZ1000B LTD, this bike is in pretty decent shape for being 30 years old and has many new parts just recently installed. It has brand new carburetor intake boots, new battery, new plugs, oil and filter, new points and condensor kit,4 brand new K & N air filters, new fuel filters and fuel lines. It's has a full Kerker racing exhaust on it that sounds amazing. Also has Pirelli tires that have at least 50% tread left. The bike runs strong up until about 6,000 RPM's and then it starts to break up a bit. The carbs were cleaned out but not sure what the problem is. They might need to be cleaned again or the points might have to be adjusted. I don't really see this being a huge problem as there is good low end power. The chrome could use a little polish and paint could use some wax but the overall condition of the bike for it's age isn't bad. I just had a baby and have no spare time to dig into it anymore.Pics will be provided upon request.
- wireman
- Visitor
Post edited by: wireman, at: 2007/03/22 22:58
- steell
If it's throttle position related, then it's most likely fuel related.
Remember those two sentences, they will save you an enormous amount of time when diagnosing engine running problems.
- Thank you received: 2098
- riverroad
- 1980 1000LTD B4
- Thank you received: 7
Tha guys ad mentions new air filters and a Kerker exhaust. I'm wondering if he rejetted it. But it sounds more like an ignition problem to me. Advance weights stuck maybe? Cheap points bouncing?
- patmann
- Thank you received: 6
The frame has a different rake to it.
The wheels are mags not wire.
The front mag was a larger size diameter. 19" ??
The rear mag was smaller diameter.16" ??
It came with bigger sized white lettered GOODYEAR tires.
It comes with dual front disc brakes and a rear disc
brake.
The fenders are different/ smaller.
The tank is smaller.
The headlight and gauges housings are chrome not painted.
It does NOT have healight "ears"/ mounts like a standard KZ. It uses a mounting system more behind the headlight.
The front turn signals are rubber mounted to the LTD handlebars, and are also a front running light. And not mounted to the headlight as the KZ is.
The exhaust system is a "custom" one by Jardine.A four into two system.
The handlebars are more of a "pullback" aka "LTD" bars.
It comes with shorter mirrors aka "LTD" mirrors.
The seat is a as you called it "two tiered" aka "LTD" seat. Thus allowing a flat footed seating for people of shorter height. It also helps for to keep you on the bike after that handfull of 1015 cc of Kawasaki starts moving. P.S. don't Armor All it too much ...
The rear grab bar is different from the standard KZ. As it it taller to match the LTD seat.
They came with a "custom" paint job and decals.
I'm sure I've missed something :dry:
I've owned a 1976 900 LTD, three 1977 1000 LTD's.
So I know something about them. And my present 1974 900 Z1 has been changed to look like the LTDs.
Oh !!! LTD stands for LimiTeD as they ( Kawasaki ) only had plans on making a VERY Limited amount of them in 1976. But they sold like hotcakes.
Someone will correct me I'm sure but I would guess Kawasaki made 15-20 standard KZ for every LTD. And the LTD was put together in the good ol' U.S. of A.
Post edited by: patmann, at: 2007/03/23 11:56
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
- wireman
- Visitor
i think you pretty much summed it up:PI'm getting old so this is what I can remember..
brake.
Someone will correct me I'm sure but I would guess Kawasaki made 15-20 standard KZ for every LTD. And the LTD was put together in the good ol' U.S. of A. <br><br>Post edited by: patmann, at: 2007/03/23 11:56
- ltdrider
- Thank you received: 17
One more thing...
Chrome chain guard on the LTD!
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
- wireman
- Visitor
- RonKZ650
- Thank you received: 240
- wireman
- Visitor
- ltdrider
But you can't mount a center stand unless you change the exhaust pipes. Those 4x2 Jardines run under the engine, and will interfere with the center stand.
Greensboro, NC
