KZ1000 P, handling question
- z1rick
12 Mar 2007 19:44
I have a '99 1000P, with 42xxx on the clock. It seems to handle fine up to 60MPH, but, when I hit 65 or 70 on the freeway, going straight, I don't feel comfortable on it. seems to have a slight rear wobble, and minor shimmy from the front. Here is what I know, the rear shocks are stock, and on the stiffest setting, Tires are Dunlop K327 rears, Dunlop F16 front. Look to have about have of their tread. I had the bike in the shop for a major tune-up, they replaced the swingarm bushings, rebalanced the tires, inflated the tires to the proper PSI. What else should I do to get better handling? I am thinking of replacing the tires, witch brand and model would you recommend? I want to keep it close to a sport touring Bike. Would a fork brace help? Steering dampner? I can spend a few hundred on it. Thanks for the advice
Anaheim CA
1999 KZ 100P
1974 Z1 900 Project
1977 (2) KZ 650 projects
1999 KZ 100P
1974 Z1 900 Project
- Pterosaur
Re: KZ1000 P, handling question
12 Mar 2007 19:58
I'd give the neck bearings a good looksee.
If they're original with 40-odd on the clock, they're likely shot, and will give you the symptoms you're noticing.
Go for tapered rollers, much superior to ball bearings.
While you're at it, a little trick I did on mine after noticing that the bottom surface of the lower bearing is essentially open to the elements was to trim a rubber diaphram to fit over the bearing cap, then packed it with grease to keep road gunk outta there.
- z1rick
12 Mar 2007 20:21
Thanks for the tip, I will try that, Z1enterprises here I come...
Anaheim CA
1999 KZ 100P
1974 Z1 900 Project
1999 KZ 100P
1974 Z1 900 Project
- kzwolfsr
12 Mar 2007 20:51
Depending on your weight you might want to bring down the settings according to your weight also
Original man of the Caribbean
- z1rick
12 Mar 2007 20:54
Yeah, I thought about that, just difficult to get to the shock adjusters, with the sidesaddles and crash bars on. But, I will drop the settings to the middle, and try that. Oh, by the way, I just ordered the stearing bearings from Z1E, they have a kit with the seals...
Post edited by: z1rick, at: 2007/03/13 00:02
Anaheim CA
1999 KZ 100P
1974 Z1 900 Project
1999 KZ 100P
1974 Z1 900 Project
- kzwolfsr
12 Mar 2007 21:12
Thats cool. I have to start my 1000 project soon. Fork rebuild, new seals, change oil again, along with new magnetic drain plug and get out those broken bolts in my clutch cover and find that noise in my bike's rear end, possibly bearings for the wheel and somethingelse I can't remember right now. I gotta write this down
- vipex
15 Mar 2007 09:04
Pterosaur wrote:
I could not agree more. If the problem continues let the forum know....if it goes away tell us as well...
- z1rick
15 Mar 2007 20:13
Thank you all for the tips, as soon as I get my stearing bearings, and get them installed, it's off down the freeway...
I will post again once I know how she is doing... Also, I am going to purchase the Craftsman Bike lift, someone posted a link for it in ChitChat, I will let you know how that goes as well.
Anaheim CA
1999 KZ 100P
1974 Z1 900 Project
1999 KZ 100P
1974 Z1 900 Project
- Bluemeanie
18 Mar 2007 05:08
As a mechanic I've learned to ask this question... Did this problem start after you got it back from servicing? If so, it was NOT there before the work done. You need to check their work. Something not adjusted right, something loose? (My first impression was low tire pressure) Let us know...
- Pterosaur
18 Mar 2007 09:12
Bluemeanie wrote:
Entirely cool way to look at the issue.
Though the original post didn't specify, the implication is that the condition existed before the shop got ahold of it - hence the bushings and tire swap, etc...
But oh yeah, a loose swingarm bolt will definitely cause that kind of feeling at those kind of speeds...
Double checking shop-performed servicing is *always* a good idea.
Still, at "42xxx", I'd expect those neck bearings to fall apart as soon as daylight hits 'em...
- RetroRiceRocketRider
18 Mar 2007 12:55
A couple of things not mentioned could also possibly cause what you're experiencing:
1) Mis-matched (diff brand or compound) tires can sometimes cause instability that might not be noticeable at low speeds, but will make you very aware of it at higher speeds.
2) Worn or damaged cush damper, which is located directly behind the sprocket hub on the rear wheel.
3) Worn front and/or rear wheel bearings or spacers.
4) Ribbed treaded (straight grooved pattern) front tires are notorious for catching those little rain grooves in the freeways here in So Calif, and will certainly make the bike feel "squirrely" at speed.
Have you had a chance to take her up to the speed where she feels unstable on a plain old asphalt or concrete road w/out rain grooves yet?
That would at least rule out the ribbed tread pattern issue.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- BSKZ650
18 Mar 2007 13:49
I know you said it was at the shop and the tires have proper air ,,but do the tires show any signs of cupping, sign of tires starting to wear out
77 ltd1000, current rider
76 kz900, just waiting
