Frame bobbing
  • flht1997
  • flht1997's Avatar
Re: Frame bobbing
12 Mar 2007 08:40
#119467
here's mine. i welded in a plate, 1 to keep water out and also to keep the rear subframe rails from flexing out under load.
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
  • Nevco48
  • Nevco48's Avatar
Re: Frame bobbing
12 Mar 2007 11:42
#119511
Draco send me an Email address, I can't seem to PM you?
  • sheik*yerbouti
  • sheik*yerbouti's Avatar
Re: Frame bobbing
12 Mar 2007 12:57
#119531
wow helluva topic.
i'm welding in a cross piece and cutting tonight after work, I'' be sure to snap some pics even though it looks like it's been pretty well covered.
later guys.
  • sheik*yerbouti
Re: Frame bobbing
14 Mar 2007 17:55
#120224
Here's the end result of a four more frame gusset and tail chop. The last pic is probably (hopefully) a lot less elegant that what my fabricator buddy will come up with this weekend to get the frame up into the H2R tail...
Project homepage -> www.jasonfagan.com/motorsport/motorcycles/kz1000/index.html
  • westers47
  • westers47's Avatar
Re: Frame bobbing
14 Mar 2007 22:02
#120291
If you do chop the end off at least have the holes welded shut and dont bondo the holes. This would help keep some strength and its just the right way to do it. It would be a really good idea to put in a brace just to be safe.
  • sheik*yerbouti
Re: Frame bobbing
15 Mar 2007 14:52
#120472
wha? who you talking to original poster?
  • hwms
  • hwms's Avatar
Re: Frame bobbing
15 Mar 2007 15:33
#120481
Deletion
Post edited by: hwms, at: 2007/03/15 18:34
  • hwms
  • hwms's Avatar
Re: Frame bobbing
15 Mar 2007 15:43
#120483
having trouble with image size.
Will try again and then give up.
Post edited by: hwms, at: 2007/03/15 18:45
  • hwms
  • hwms's Avatar
Re: Frame bobbing
15 Mar 2007 15:49
#120484
apeman wrote:
Here's Frame Bob #2:
My suggestion.
Harry
  • snakezrx
  • snakezrx's Avatar
Re: Frame bobbing
16 Mar 2007 01:10
#120599
i bobbed the frame on my csr for my drag bobber project. i cut the rear loop off & shortened it a few inches then welded it back on.
I can beat the paramedics to my crashes by at least 10 minutes.
  • apeman
  • apeman's Avatar Topic Author
Re: Frame bobbing
16 Mar 2007 14:36
#120797
Weld the loop back on? Now there is an idea, except I cannot weld. Maybe I make it work though.
Thanks all, for your input. I will let you know what I do, and post pics.
Petaluma and Truckee, CA -- member since Jan. 23, 2003;
PREVIOUS KZs: 1980 KZ750H with 108,000 miles; 1980 KZ750E with 28,000 miles; and KZ750H street/cafe project, all sold a few years back.
This is what I do for fun, not for work. It is art, with a little engineering thrown in.
  • Shoe48
  • Shoe48's Avatar
  • Live each day as it is your last
Re: Frame bobbing
16 Mar 2007 15:05
#120808
If you look in Projects under Cafe shoe you will see how I cut then shortened my upper frame ,, :)
