Front Brake Disc KZ 1000 A2 1978
Re: Front Brake Disc KZ 1000 A2 1978
16 Jan 2007 11:23
From
www.kawasaki.com
#4 is a plastic fitting
#5 is a rubber diaphram
If not already aware, the www.kawasaki.com site can be very helpful. :)
www.kawasaki.com/Home/Welcome.aspx
When comparing part numbers between the 1978A2 (single front disc) and later 1979A3 (dual front disc), the top cap, plastic plate and rubber diaphram have the same part numbers for both master cylinder sizes. Of course the part numbers are different for the smaller 1/2 inch piston and larger 5/8 piston, and different for the entire assemblies -- the 1/2 assembly is 43015-1007 and the 5/8 assembly is 43015-1009.
Post edited by: Patton, at: 2007/01/16 14:24
Post edited by: Patton, at: 2007/01/16 14:27
Post edited by: Patton, at: 2007/01/16 14:28
Post edited by: Patton, at: 2007/01/16 14:35
Post edited by: Patton, at: 2007/01/16 14:55
Post edited by: Patton, at: 2007/01/16 15:00
- Zinamia
16 Jan 2007 12:04
Patton wrote:
But, I think I have made a great stepp. As I have told, the german dealer Klamso has a piston with 14 mm in the online-catalog. On my part I find the following No. (see pic, "under-side") It seems, I have the master-cylinder with the smaller piston.
Post edited by: Zinamia, at: 2007/01/16 15:06
I was on this side, but as you have told me, that´s the master-cylinder of the douple disc, with the bigger piston. On the posted micro-fish, I have no comparisson possibilitiy with my own cylinder, so I have the idea of the pic. I was hopefull to receive a pic with an original cylinder, like in total black or any else with a "big" difference to my pic. (sorry for the bad explanation in english)(math.= bad english+bad technical ackn.= Fiasko [/img]From www.kawasaki.com
- Zinamia
16 Jan 2007 12:12
Patton wrote:
Hi Patton,
sorry for the post before, I have to go deeper in your explantion. :whistle: I was too fast an a little tired.
Post edited by: Patton, at: 2007/01/16 14:55<br><br>Post edited by: Patton, at: 2007/01/16 15:00
Hi Patton,
16 Jan 2007 12:43
Zinamia wrote:
The under-side markings on my 1978 KZ1000A2 front master cylinder (used with single front disc) are exactly the same as shown in your photograph. Perhaps the "14" is millimeters which is 0.55 inch (close enough to say 1/2 inch). Your photograph is of a 1/2 inch bore master cylinder (the master-cylinder with the smaller piston).
Patton wrote:I was on this side, but as you have told me, that´s the master-cylinder of the douple disc, with the bigger piston. On the posted micro-fish, I have no comparisson possibilitiy with my own cylinder, so I have the idea of the pic. I was hopefull to receive a pic with an original cylinder, like in total black or any else with a "big" difference to my pic. (sorry for the bad explanation in english)(math.= bad english+bad technical ackn.= Fiasko [/img]From www.kawasaki.com
<br><br>Post edited by: Zinamia, at: 2007/01/16 15:06
- Zinamia
16 Jan 2007 13:21
Patton,
Thanks for the confirmation and your patience. Now I can go sleeping (better than last night, night-mare of brakes, disk and Mastercylinder :sick: :ohmy:
To finish my projekt of double brake, I have to sell my house in the states
Post edited by: Zinamia, at: 2007/01/16 16:25
- Zinamia
17 Jan 2007 14:03
Hi together,
by my friends Z (BAD - Q 80) Z 1000 A1 1977, Europe-Modell, with Douple-Disc, we find "under"-side of the round Master-cylinder 5/8. This is near 16 mm. (see pic)
Why we have now a inch-"tatoo" by an europe Z and a mm-"Tatoo" by a US-Modell, don´t ask me :blink: :dry:
Post edited by: Zinamia, at: 2007/01/17 17:10
Post edited by: Zinamia, at: 2007/01/17 17:12
