630 to 530 chain conversion.
- AHRMA120
Re: 630 to 530 chain conversion.
26 Dec 2006 17:00
I use a 520 chain and it works well. 520 is almost identical to a 530 chain in strength. They use them on GSXR 1000 in full race trim. I think it would be fine and is far lighter. ZR550 front sprocket will work on all Kaw's. Rear sprockets can be had from sprocket specialties.
- caffcruiser
26 Dec 2006 17:16
AHRMA120 wrote:
The 520 is nearly identical in strength when new, but that's not the same as after many miles.... The 520 are run on the race bikes because they need shave off every pound they can... and it does make a difference that they change out chains and sprockets after or during a lot of races. They get almost no miles compared to a chain on a regularly used streetbike.
Post edited by: caffcruiser, at: 2006/12/26 20:19
