I don't know if the 650 wiring is the same or similar to the 1000, but, again, I would check the connections of the positive stud on the starter solenoid where the battery lead attaches from the battery. On one model this is where power diverts from the battery to the starter one way and everything else the other way. A loose connection or corrosion here could cause the problem you are describing. Also, on this model there is an in-line connector in a small wire (that powers everything but the starter) just off the stud that you should check for corrosion. On a different model, the in-line connector that supplies power to everything else (except the starter) comes off the positive post of the battery, then has an in-line connector. If you have this, check the connector for corrosion. I'd check the turn signal relay for a short, also. Good luck.
Post edited by: vegasjetskier, at: 2006/10/25 19:52
