more ignition coil info needed
- Bob_79KZ
Re: more ignition coil info needed
10 Oct 2006 11:39
Lou: Great stuff...thanks again for all the info and pointing me in the right direction.
One further note: I've ridden motorcycles for over 20 years and I've neverhad a coil, or any other ignition part fail me. That goes for my Harley's, kaswsaki's, susuki's, and Honda's.
Same with the electronic ignition in my cars...Zero failures. They build this stuff to last.
I find that you don't have problems until you start putting in non-standard parts. From then on you are plaqued with mystery problems.
And yes, I know, I'm messing around with different coils for my KZ so I'm gonna have mystery ignition failures. It's a risk I'm willing to take for the sake of science....
Keep the sunny side up,
Bob
Bob
- loudhvx
10 Oct 2006 22:38
Yeah, if I could get original parts at a reasonable price, I would do it. Most of my mods are because parts are not available or way overpriced.
The only KZ parts that failed me were some coils, but that was after I rode through several huge downpours on a road trip. I also had a neglected clutch cable break on me. Overall, not bad for close to 15 years on 25-year-old bikes.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- wagonmaster69
- 78 KZ1000A2 / 82 KZ1100 Spectre
16 Oct 2006 15:11
You are write now you gotta find out abought the coil mod for even lower price coils.
- Duck
- e vica na i sau na ga
16 Oct 2006 15:37
750LTDRider wrote:
P
* V
V
* R
P = V^2 / R
V is fixed at nominal 12V
R is in the denominator
Larger denominator means smaller value, in this case smaller P
First of all, plain and simple, the higher the resistance, the more heat is generated. That is simple electronics. And of course this is at the same voltage and current source. The higher the resistor value, the more voltage it will drop, and that energy has to go somewhere, and it results in heat dissipation.
P
* VV
* RP = V^2 / R
- steell
16 Oct 2006 17:28
Duck wrote:
Long story short (and no math needed)
Resistance increases, current decreases, voltage increases.
Want to see it in action?
Watch the voltmeter (if you have one) in your car, when you start it you run the battery down and the battery resistance decreases, after starting voltage will be low because the resistance at the battery is low and maximum current is flowing, as the battery charges you will see the voltage increase because the resistance of the battery is increasing and the current flow to the battery is decreasing.
Is that simpler, or more complicated?
P* V
V* R
P = V^2 / R
- Bob_79KZ
16 Oct 2006 18:17
Steell:Whew....that went right over my head!!!
Bob
Bob
- wireman
16 Oct 2006 20:57
steell wrote:
P* V
V* R
P = V^2 / R
- loudhvx
16 Oct 2006 23:08
Actually, in circuits that show a battery, the battery is assumed to be an "ideal" battery. That is, it's resistance is assumed to be zero and the battery is thought of as a pure voltage source. In reality, a more accurate representation would be a voltage source in series with a resistor.
As the battery goes dead, the voltage of the battery remains the same, but it's resistance increases. This causes the apparent voltage to drop because the resistor drops the voltage when current is flowing. But if we put a voltmeter on the physical battery the voltage is still close to that of the fully charged battery. That's because a voltmeter takes very little current.
Measure the voltage of dead AA battery and a new AA battery. The voltage will only be slightly lower on the dead one. But then put a load on the batteries. Then the apparent voltage on the dead one will be very low compared to the charged one. The dead one has a large resistance in series with it's voltage, but the charged one has a very low resistance in series with it's voltage.
Post edited by: loudhvx, at: 2006/10/17 02:09
1981 KZ550 D1 gpz.
Other links.
Other links.
- jack2006
17 Sep 2007 16:58
One quick one...GM HEI IGNITOR...what cars did it go in...everytime i call a parts store for one they ask me what car is it off cuz they can't find one...I tolde them any generic GM ...and they're like we need a car...BTW i'll be making the IC ignitor from the instructions that are above....new one is way to expensive and the 1 hour spend making your own is a fun excercise anyhow
- loudhvx
18 Sep 2007 11:10
I believe most GM v-8 cars from mid 1970's will have it.
I think I asked for a 1977 v-8 Camaro or Nova. Make sure it looks like the one in the photo on my site.
www.geocities.com/loudgpz/GPZgmHEImod.html
That one is a Wells DR100.
The Niehoff (Borg-Warner?) DR400CS appears to be the same unit. Most places are selling the Niehoff part now.
1981 KZ550 D1 gpz.
Other links.
Other links.
- jack2006
18 Sep 2007 16:01
friggin partsource wants 54 bucks for the 400...gots to keep lookin,...they dont carry the 100
- jack2006
19 Sep 2007 07:18
Ok the Wells is not the easiest to find in Canada...)Toronto) I called all the major suppliers even the shop suppliers...the cheapest i and mind you not a wells was for 45 bucks...considering i need two...i don't know if it's worth making one myself.
Now if there is anyone out there who knows where to get two of them for a reasonable price here in Toronto please let me know...
Ok i'm off to pick up my tires
and the clutch perch
I'll check here in a few hours to see if anyone has any suggestions
