Stator, should I replace
- OKC_Kent
Re: Stator, should I replace
20 Sep 2006 10:10
kaverryan wrote:
You lost me.
Here you say the battery voltage is lower at 4000 rpm, in your first post you state just the opposite, that it's higher...
:huh:
Check this out, it helped me and is easy to follow. Make sure your battery is fully charged.
Electrosport Fault Finding Diagram in our Database
Post edited by: OKC_Kent, at: 2006/09/20 13:17
The battery DC lowers when idling and even less at 4000RPM. I believe if the charging system is working it should go up to about 13.5. So I unplugged the two yellow wires coming from the stator (dynamo in the manual) and checked for........ okay as I'm writing this I realize I'm not checking for AC at these wires. This is not my strong point! I'll recheck the afternoon when I get off work and let you know what I find. Thank you for your help.
You lost me.
:huh:
Cashion, OK
78 KZ650 B2 85,000+ miles
- kaverryan
20 Sep 2006 17:04
I followed the diagram and here is what I found. Yes I was checking the output wrong and yes I had a broken wire. I now have 60v outpur, not the 75 my manual says but I think it will be okay. Things seem to be better. Thank you for your replies and assistance.
- Sandy
- Fly High,Tony
20 Sep 2006 20:03
Just out of curiosity,Bud...where WAS the broken wire?
1977 KZ1000 A-1
- kaverryan
