BOTH coils melted on my 81' KZ1100 !!
- wireman
- Visitor
- dgiardina
From what I've read so far, I should get at least 110psi per cylinder, right?
Also, do I need to take into account the compression ratio for my bike? It's 8.9:1
Thanks to all for pointing me in the right direction. I really appreciate it.
Dale
- wireman
- Visitor
- wagonmaster69
- 78 KZ1000A2 / 82 KZ1100 Spectre
- Thank you received: 4
- dgiardina
Removed the plugs, full throttle, cranked it 8 times on each cylinder & here's my results from Left to Right:
125, 130, 125, 135
Remember, I can't start it to get it warm & I didn't add a teaspoon of oil to check the rings, but otherwise that sound right to y'all?
Dale
- wireman
- Visitor
- steell
yeah they are pretty close together,checking valve clearances might bring them up a little but i think it will live.now change that oil and while you are changing coils check the rest of wiring under tank and seat to make sure nothing else got hot and melted.
And consider your self "very" lucky, and don't ever do that again!! :woohoo:
That's death on an air cooled motor.
- JMKZHI
- Thank you received: 48
- dgiardina
Regarding the blued pipes - not any more than they already are (which isn't all that bad)
- loudhvx
- Thank you received: 1616
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- dgiardina
- wireman
- Visitor
