Harness
  • wagonmaster69
  • wagonmaster69's Avatar Topic Author
  • 78 KZ1000A2 / 82 KZ1100 Spectre
Harness
21 Jul 2006 10:47
#63675
I'm getting a 78 KZ1000 and it has been sitting for a while and I was wondering am i better off with buying a new wireing harness at over $300. or do to the fact that I am preaty good not great :whistle: but good with the wireing should I take out the old harness and rebuild it?
I have seen other links were another member has done it is it that hard and will I need any thing ells to compleat the harness?
  • 77Davo650
  • 77Davo650's Avatar
Re: Harness
21 Jul 2006 10:54
#63678
I did my own harness for my bike and used all new connectors and wire (keeping the old harness laid out for reference) and it took me about a week or two working on it after work at nights. I think it ended up costing about $75 for the wire and the connectors and the fuse box switch. I also made sure to have a couple different versions of the electric wiring diagrams to make sure I knew what I was doing. It wasn't that bas as long as you keep everything color coded and marked and laid out neatly.
77 KZ650 C1 (sold)
78 KZ650 B2 (sold)
78 KZ400 B1 (sold)
78 kz400 C1 (resto-mod)
78 kz400 C1 (hardtail low chop)
couple of possible project kz's in parts
  • ltdrider
  • ltdrider's Avatar
Re: Harness
21 Jul 2006 10:59
#63680
Is your wiring shot? Are you having electrical problems with the existing wiring?
My bike is two years older than yours, and she's got all of her original wiring. Just because it's old may not necessarily mean that it should be replaced.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
  • wagonmaster69
Re: Harness
21 Jul 2006 11:06
#63684
Well here is a picture of the bike I think I sould replace the old wire on it just by the look of it.
  • ltdrider
  • ltdrider's Avatar
Re: Harness
21 Jul 2006 11:11
#63686
Ummmmm....
Sorry Wagonmaster.
Your point is well taken.
Burns my a$$ when I see a Kaw that's been abused by the PO.
Greensboro, NC
  • loudhvx
  • loudhvx's Avatar
Re: Harness
21 Jul 2006 12:14
#63699
The problem is, even if the bike is well taken care of, there are spots where the wiring gets a lot of stress, most notably where the harness goes from frame to headlight.
Buying a good used harness has the same problems. A brand new harness would be fine, but $$$$$$$$$$$$$.
The wires may look fine on the outside, but the problem is on the inside. Through repeated bending, the copper breaks before the insulation. The only sign may be what appears to be a small insignificant bump in the wire. The bump may indicate internal breakage of the copper strands. It's hard to find all of the bumps without totally dissassembling the harness. By then, you may as well replace the wires.
It's definitely something you wouldn't want to do as a beginner unless you have a ton of time to study it. However, if you're pretty experienced and understand the way the ignition and charging system works, it should be pretty easy.
You can get rid of a lot of things if you want, as well, like the reserve lighting unit, as long as you somewhat understand their functions.
But either way, if the bike is ratty or nice, I wouldn't replace the harness if you're not having any problems (how often does THAT condition last, though :) ).
Post edited by: loudhvx, at: 2006/07/21 15:16
  • donthekawguy
  • donthekawguy's Avatar
Re: Harness
21 Jul 2006 14:54
#63739
Where are you finding a harness for $300. I would buy one in a second at that price! All the after market places I have seen don't make them for 77-78.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • trippivot
  • trippivot's Avatar
Re: Harness
21 Jul 2006 18:29
#63770
make a inquiry at MRCYCLEPARTS.COM just try I use this site a lot.
  • wireman
  • wireman's Avatar
Re: Harness
21 Jul 2006 19:48
#63791
has the stock wiring harness been butchered up?if it hasnt been hacked to pieces how about just cleaning it up really good and just replacing whats bad?thats part of the fun of working on these bikes is figuring out whats good and whats bad .:P
  • wagonmaster69
Re: Harness
21 Jul 2006 21:57
#63819
If you go to AmericanClassix.com and they have the harnesses.
  • vic44139
  • vic44139's Avatar
Re: Harness
22 Jul 2006 06:28
#63846
If there is stress at the neck, just pull off the tank and adjust it down the frame. Bottomline, its your cash and time involved. Personally, I would just start replacing connectors that look bad. I kinda got that "Don't fix it if it's not broke" mentality.:lol:
  • pumps
  • pumps's Avatar
Re: Harness
22 Jul 2006 09:22
#63864
The ol' 1000 does need some TLC doesn't she? You'll get her there. Pretty sad to her looking like that though. Good Luck.
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
