Replacement Spark Wires and Caps/boots
- bluejacobs
26 Apr 2025 06:57
Hey all, so this was something I was looking at last year after the crash when putting the bike back together - the spark wires and caps/boots appear to be original and one of them was arcing which I discovered when I touched the header while the bike was running, warming up. I had a parts bike at the time, so I swapped on a cap from that bike and rode it the rest of the season, but now that the move is complete and my garage is at least somewhat in order, I'm starting to address the punch list of items I want to take care of and new spark wires and boots was one of them. Electrical stuff has never been my strong suit, so I was hoping someone could point me at the correct leads and caps for my 1981 KZ750 LTD - I know I can get 7mm solid core bulk wire at NAPA but beyond that, I'm kind of confused with wires/plugs/caps being resisted or not and how the wires all go together, or if there are pre-assembled options that might be better? My preference would be to pick up parts locally but if someone has links to a setup that will work well for my ride that they wouldn't mind sharing, I'd appreciate it. If I remember correctly from searching the forum last year, the OE B8ES plugs were discontinued as well as the NGK OE replacement caps for some reason... help?
1981 Kawasaki KZ750 LTD - crashed 4/24, rebuilt and rode the rest of the year; undergoing DD/TLC
1981 KZ440 A - was running until the end of 2022, sitting in a barn for now
1981 KZ440A - donor bike
- ckahleer
Re: Replacement Spark Wires and Caps/boots
26 Apr 2025 08:00
I used bulk 7mm plug wire on my zl600. Was unable to get the wire coverings off the old wires and could not find a source of new covers. The two options I found so far are 5/16" thin wall fuel line or heat shrink.
With a flat blade screwdriver, you can dissemble the plug boot. Unscrew the brass sparkplug fitting. Now dump out the 5K resistor and spring. Clean everything up and put back together.
If you still want new plug caps, this will let you know if you need 5K caps.
1997 ZL600
94 KE100
82 KZ305
74 TC185
94 KE100
82 KZ305
74 TC185
The following user(s) said Thank You: bluejacobs
26 Apr 2025 08:05 - 26 Apr 2025 08:15
The wires unscrew from your existing coils and plug caps.
Remove them, then use some WD-40, and shoot under the outer lead protector tubes, and remove them. Push a stiff wire between the tubes and spark plug lead to create a gap, for WD-40 flow, as needed, in order to get the tubes loose.
Purchase 7mm copper core spark plug lead wire, and cut to size.
Check your old spark plug caps for resistance. They should be 5000 ohms each. If significantly different from this, remove the resistor using a screwdriver, clean and check again. If this doesn't work, replace the caps. There are various aftermarket options.
Before installing the new spark plug leads, install the outer protector tubes onto your new leads. Again, WD-40 inside the outer protector tubes allow them to slide on easily.
Regarding spark plugs, go find some NOS NGK B8ES plugs, or, easier to find, buy NGK W24ES or W24ESU spark plugs. Do NOT buy resistor plugs, such as B8ESR plugs.
P1010602
by
nessism
, on Flickr
Last edit: 26 Apr 2025 08:15 by Nessism.
- bluejacobs
26 Apr 2025 09:18
So NAPA offers two different "bulk" wires -
www.napaonline.com/en/p/BEL734803
www.napaonline.com/en/p/BEL734601
Is there any real difference between these? Which is what I'm looking for, as neither explicitly say "copper core" anywhere that I saw? Thank you and apologies for my ignorance on this
- Injected
26 Apr 2025 11:59 - 26 Apr 2025 12:02
You can buy "bulk" spark plug wire from a good automotive speed shop. They also usually sell the terminal ends and most of the different boots. If you don't have anybody local just go on the Jeg's or Summit web site.
I started to be interested in DIY spark plug wire sets as the ready to go motorcycle kits by Dyna and Taylor were getting too pricey.
I walked into a local "speed" shop and bought a Accell plug wire crimper and some bulk MSD wire. They also had Accell and Moroso brand wire as well, most of the wire is solid core specifically designed for racing purposes.
Lately I just buy any on sale quality brand V8 kit I can find and cut to length then reuse the terminal ends and boots if they are at the correct angle. The V8 kits are plenty long and you can get 2 sets for less than one set of a motorcycle specific kit. If the boots are wrong you can buy those separately.
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
Last edit: 26 Apr 2025 12:02 by Injected. Reason: info
26 Apr 2025 13:58I don't think either of those wires are correct. You want copper core, non suppressor wire. I got mine at Z1, some time back. I don't see the same wire currently on their site, but it's available in the markeplace.So NAPA offers two different "bulk" wires -
- sf4t7
26 Apr 2025 14:58 - 26 Apr 2025 14:59
Ton's Performance is a company selling bulk plug wire, caps, terminals, and other wiring accessories. I found everything I needed to make up my plug wires. Good quality parts and reasonable prices. Get a few extra terminals and a some extra length on the wire to practice on.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
Last edit: 26 Apr 2025 14:59 by sf4t7.
26 Apr 2025 15:26Ton's Performance is a company selling bulk plug wire, caps, terminals, and other wiring accessories. I found everything I needed to make up my plug wires. Good quality parts and reasonable prices. Get a few extra terminals and a some extra length on the wire to practice on.
One of the nice things about the stock setup is you don't need any terminals or wire accessories. The raw wires screw into the coils and plug caps.
- saltroni
27 Apr 2025 11:52
I am using TONs also. I went retro with yellow wires and orange NR caps.
Ignition parts and accessories – Ton's Performance
- JR
27 Apr 2025 18:25
For anyone in Ontario, Canada I'd recommend Aircraft Spruce, 7mm copper core unshielded Rotax ignition wire
www.aircraftspruce.ca/catalog/eppages/spkplugwire.php
27 Apr 2025 18:43Aircraft Spruce is also a good source of ACF50, a near-magical elixir.For anyone in Ontario, Canada I'd recommend Aircraft Spruce, 7mm copper core unshielded Rotax ignition wire
The following user(s) said Thank You: JR, Vinsky
- sf4t7
28 Apr 2025 09:11
Hey Saltroni, I made the yellow with orange plug caps also. Like the Accel wire set I had on it in the 80's
Scotty
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
