- Thank you received: 11
LED taillight (kz400)
- ThatYeti
26 Jun 2024 18:19 #901392
by ThatYeti
'76 KZ400
Replied by ThatYeti on topic LED taillight (kz400)
Thanks? I think. Only have it mocked up with it all just pressed together cause I don't want to cut and crimp it all without knowing it'll work and then be stuck shaving down the wiring to nothing every time I have to start over.
'76 KZ400
- Thank you received: 2301
27 Jun 2024 03:53 #901403
by Wookie58
Replied by Wookie58 on topic LED taillight (kz400)
The following user(s) said Thank You: ThatYeti
- ThatYeti
27 Jun 2024 04:17 #901404
by ThatYeti
'76 KZ400
Thanks, will give that a try later. Given the light works as expected when I give it direct power from a battery, would that indicate the integrated circuit board is still ok?
'76 KZ400
27 Jun 2024 04:18 #901405
by Wookie58
The above tests will soon tell youThanks, will give that a try later. Given the light works as expected when I give it direct power from a battery, would that indicate the integrated circuit board is still ok?
- ThatYeti
27 Jun 2024 15:30 - 27 Jun 2024 15:30 #901420
by ThatYeti
'76 KZ400
Ok, couple updates. Tested the stock light and it still works fine. But interestingly doesn't show a 'running' light at all, only lights up when you pull the brake lever.
Rewired the new light with bullet connectors and plugged it in. Works the same as the stock light but when the brakes are active, it does a very faint strobe. So only a slight difference from the stock unit.
Going to try testing with the multimeter but I'm very much an idiot with it so no promises.
'76 KZ400
Last edit: 27 Jun 2024 15:30 by ThatYeti.
- ThatYeti
27 Jun 2024 15:34 - 27 Jun 2024 15:37 #901421
by ThatYeti
'76 KZ400
Not sure what this means but I followed the instructions and got 1.659 when the key is on and a zero when I pull the brake lever but the meter beeps.
'76 KZ400
Last edit: 27 Jun 2024 15:37 by ThatYeti.
27 Jun 2024 17:51 - 27 Jun 2024 17:52 #901425
by Wookie58
You need to set the meter to V-- (dc volts) it might be worth you reading my fault finding guide (link is in my signature)
PS: the wiring is now "spot on"
Last edit: 27 Jun 2024 17:52 by Wookie58.
- ThatYeti
27 Jun 2024 18:12 #901426
by ThatYeti
'76 KZ400
Thanks and ok, switched the setting and also plugged the red wire into both the brake and running light just to be sure. Pics of each without/with the brakes on
'76 KZ400
- 1kz4me
- Thank you received: 6
27 Jun 2024 19:17 #901427
by 1kz4me
Replied by 1kz4me on topic LED taillight (kz400)
Thatyeti, hi hope you don’t mind me chiming in. Your last pic shows meter set up correctly DC setting. Now connect black lead from your meter to Negative post on your battery or a place on the frame, then to make sure meter is working correctly touch with the red lead the Positive post on battery. See what you get, if battery is charged you should get about 12volts. Now use the red lead to touch the wires you joined. Put your red lead on one wire and hit the brakes see if you get 12volts. Do this for each wire you spliced together. It’s a troubleshooting process but this will get you handy with the meter. Patience it’s a process
- ThatYeti
28 Jun 2024 04:08 #901433
by ThatYeti
'76 KZ400
Appreciate any help, so thank for you chiming in. Will give that a shot later, and try to follow what you've got there.
'76 KZ400
- ThatYeti
28 Jun 2024 05:29 #901434
by ThatYeti
'76 KZ400
Ok tried that and got 12v from the battery I think (first pic). Trying it with the connected wires I get zero l without pulling the brakes and a tiny bump when I pull it on the brake light circuit, nothing on the running light circuit at all regardless.
'76 KZ400
28 Jun 2024 07:01 #901439
by Wookie58
Can you confirm when you took these readings that the ignition was switched on
