Electrical problems?
  • SmithDubs
  • SmithDubs's Avatar Topic Author
Re: Electrical problems?
15 Jul 2022 20:29
#870437
What do the two black and yellow wires goes to that comes from the solenoid? I can’t read the wiring diagrams as they do not zoom in close enough before getting blurry. What do they control - bought a new starter - starter works great - but when I press the button noting still - but first what do those black/yellow wires do?
  • SmithDubs
15 Jul 2022 22:06
#870440
Ok, so when I shorted out the old starter my flashers stopped working - after putting in a new starter (which works) and putting in a new solenoid (it works as well) when I go to start nothing happens - the lights go dim but nothing clicks nothing - my blinkers do not work as well - I am stumped - I am confused - ever since I caused a short when I go to start the bike this Solenoid used to click then it didn’t also after the short my blinker stopped working what am I missing here folks
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
16 Jul 2022 02:10
#870445
At the solenoid "Black" is the switched live from the starter button - "Black/Yellow" are ground
Do you have a voltmeter and are you comfortable with it ?
You could take a piece of wire "with a fuse in it" and jump the battery live from the big terminal on the solenoid to the "Small Black wire" on the solenoid - if the starter, solenoid and battery are good the solenoid should click in (as long as it has a ground on the Black/Yellow) and the engine should crank MAKE SURE IT IS IN NUETRAL AS THIS BY-PASSES THE SAFTY CIRCIUT (clutch switch, side stand switch etc)
If the engine cranks then check the following
  • Votage at black switch wire when the starter button is pushed ( red meter lead on switch wire, black meter lead on battery negative terminal)
  • Then move the black meter lead to the black and yellow wire at the solenoid and repeat
Wha.t voltage readings do you have ?
