KZ900 Spark Plug Recommendations
  • Lebowski
  • Lebowski's Avatar Topic Author
26 Jul 2021 10:35
#852574
76-KZ900 here. Do any of you guys foresee an issue with using BP8ES instead of B8ES for my bike? I believe the only difference is that the BP8ES are extended, so I would think clearance with the piston would be the only problem if there was one? If this is not an issue, my next question is what  spark plug boots do you recommend?
Thanks
Re: KZ900 Spark Plug Recommendations
26 Jul 2021 10:59
#852577
Clearly I do not understand.  Why would you not use the spark plug that the folks who designed the engine recommend?  Ed
  • Lebowski
26 Jul 2021 11:48
#852581
Fair point. Because I happen to have a set of BP8ES available.
  • hardrockminer
  • hardrockminer's Avatar
26 Jul 2021 12:12
#852582
...and they no longer make the B8ES plug.....unfortunately.
  • BCScott
  • BCScott's Avatar
26 Jul 2021 14:10
#852588
ND W24ES are what I use in my KZ1000A1
Back in the saddle and loving it! KZ1000A1
  • Nessism
  • Nessism's Avatar
  • Away
26 Jul 2021 16:21
#852599
W24ES & W24ESU are good if you can't find B8ES.  Stay clear of BR8ES if you can since it has a resistor built in.
NGK plug caps are similar to the OEM caps.  They have a resistor built in (thus the plug doesn't need one.)
The stock wires are copper core.  Not suppression core, like car wires, which are resistance type.
26 Jul 2021 17:59 - 26 Jul 2021 18:03
#852602
Perhaps, but apparently the B8ES plugs are still available.
www.amazon.com/NGK-B8ES-Standard-Spark-Plug/dp/B000A8OVIY
Last edit: 26 Jul 2021 18:03 by 650ed.
  • willemZ900
  • willemZ900's Avatar
  • Z1B 4 ever
26 Jul 2021 21:58 - 26 Jul 2021 21:59
#852610
I asked my local motorcycle dealer about the availability and production of the NGK B8ES. He knows nothing about it and can order as much as he wants (the Netherlands)
Last edit: 26 Jul 2021 21:59 by willemZ900.
  • hardrockminer
27 Jul 2021 04:04 - 27 Jul 2021 04:06
#852614
You may be correct Ed.  But I've heard from several sources that they are stopping production.  It's been discussed here.  I wouldn't trust Amazon to sell NGK plugs made by NGK in Japan.  Fake NGK plugs are known to exist.
Edited to add that if they are still made, and that's the OEM plug of choice then that''s what I would use.
Last edit: 27 Jul 2021 04:06 by hardrockminer.
  • ayeckley
  • ayeckley's Avatar
27 Jul 2021 04:07
#852615
NGK makes non-resistor caps as well in all the same angles as the resistor cap. Other than the part number etched onto the side I couldn’t tell them apart visually. I think Z1 Enterprises used to carry the full range of styles, not sure if they do anymore or not. Maybe it was Dennis Kirk?
1976 KZ900A4
1976 KZ900A4
1978 KZ1000A2
1983 ZX750 A1 aka GPz 750
1983 ZX750 A1
1973 CL350K4
1984 ZX1100 A2 aka GPz1100
1969 CT90
2006 Burgman 400
  • TexasKZ
  • TexasKZ's Avatar
  • Busy
27 Jul 2021 05:19
#852617
Z1 still lists the caps, but no non-resistor plugs.
www.z1enterprises.com/ngk-spark-plug-cap...ree-elbow-yb05f.html
  • TexasKZ
  • TexasKZ's Avatar
  • Busy
27 Jul 2021 05:26
#852619
Claims to be an NGK crossover chart.
www.weeksmotorcycle.com/spark_plug.html#gsc.tab=0
