Trouble on a road trip
  • chrisM
  • chrisM's Avatar Topic Author
Re: Trouble on a road trip
14 Aug 2021 14:08
#853812
Update/solution (?)
battery was bad. Not sure if that was the cause of the other elextrical issues or not but I had to buy another new battery after replacing the ignition coils.
„Old“ battery that was replaced with stator had less than 100 cold cranking amps.
also: Green fuzzies all over 6 Pin Connector That I cleaned off. After that, everything was great.
starting to have issues again now- 3,000 miles later. Might be something in the charging system. Can’t quite figure it out but the battery doesn’t seem to want to get fully charged. Consistent starting issues- sometimes I have to push start - oil leaking all over presumably from shitty seal on the stator housing.
  • loudhvx
  • loudhvx's Avatar
15 Aug 2021 07:56
#853843
In your first post, you never mentioned why you replaced the battery, regulator, and stator  Also what did you replace the regulator and stator with?  Factory parts or aftermarket, used or new?
You may want to just start going through the FSM procedures on checking the charging system.  Do you have any extra accessories added, like lights etc?
  • chrisM
17 Aug 2021 12:17
#853955
 Replaced the regulator in the hope that it wasn‘t the stator. The place where I left it was 1.5 hours away from where I was staying, so they guy just did the work (replaced the stator/rotor) without really asking me.... but only charged me an hour of labor and I was happy he helped me out. He was slammed with work and didn’t have time to help me actually.
No idea if the parts are original Kawi or not. They are new. Rotor was used.
i think maybe there wasn’t enough oil and the stator/rotor got fried. He did a shitty job sealing up the stator compartment, so now I leak a ton of oil.
  • chrisM
17 Aug 2021 12:18
#853956
no extra lights or anything. Very basic
  • loudhvx
  • loudhvx's Avatar
18 Aug 2021 12:33
#854030
Hmm.  Well, very lucky that guy was able to slap it together for you.  It's not easy to find someone to drop everything like that.
So you will just have to investigate it.  I would start with the FSM tests though.
The stator does not need oil.  It just gets incidental oil from the starter clutch, which is located under the same cover (and the starter clutch does need the oil).  So yes that cover does get some oil build up, but there is a path for oil to return to the crankcase.  The alternator cover should not have to handle too much oil and there should be almost no pressure so it should not be too hard to clean up and re-seal with a new gasket etc.  Make sure the crankcase breather is not blocked or clogged.
