Pick-up coil failure
  • badr0bot
  • badr0bot's Avatar Topic Author
15 Jul 2021 20:27 - 15 Jul 2021 20:29
#851832
My KZ100 ran just fine the last time I rode her.  She was parked outside for about 10 days and then no spark to any of the plugs.  The kill switch is working so I thought for sure it must be the igniter so installed a new one and still no spark. Next step, check the resistance through the pick-up coils.  Clymer manual says it should be 360-540 ohms. Mine reads nothing on the hundreds setting and .445 ohms on the diode setting for both pick-ups. It's been really hot here in Utah. Could both pick-up coils fail from sitting in the sun on consecutive 100 degree days?  I can't think of any other reason they could both fail while parked.  I don't think I'm reading my meter wrong (pic attached)?
87 KZ1000 P1
Last edit: 15 Jul 2021 20:29 by badr0bot.
  • F64
  • F64's Avatar
  • 81-KZ440D2
Re: Pick-up coil failure
15 Jul 2021 21:17 - 15 Jul 2021 21:17
#851834
Check your fuses.
Key on/ignition on
Meter on DC V
Do not disconnect any of the fuses while taking these readings. Circuit must remain complete and loaded.
Black probe on battery neg post(post is the metal part of the battery)
Red probe on battery positive post.
Note voltage
Move red probe to both sides of each fuse.
Put the probe on the wire terminal connector for the fuse. This will test the terminal connection as well.
Battery voltage should be on both sides of fuse.
Turn off bike
81-KZ440-D2.
LIC, NY
Last edit: 15 Jul 2021 21:17 by F64.
  • loudhvx
  • loudhvx's Avatar
16 Jul 2021 07:09 - 16 Jul 2021 07:11
#851845
The pickups deal with much higher temperatures when the bike is idling.  It's not impossible, but unlikely both pickups would fail simultaneously.
Make sure to use the "2K" setting on your meter when trying to read the resistance.
Follow F64's test instructions.
Last edit: 16 Jul 2021 07:11 by loudhvx.
The following user(s) said Thank You: F64
  • ckahleer
  • ckahleer's Avatar
16 Jul 2021 08:21
#851850
To test the meter, find a resistor in the 100 - 1000 ohm range and read that. If you move the decimal point in your .445 reading, your dead on.
1997 ZL600
94 KE100
82 KZ305
74 TC185
  • badr0bot
18 Jul 2021 20:02 - 18 Jul 2021 20:08
#851987
The fuses check out.  12.5V at the battery.  12.5 volts at the one fuse that stays hot with ignition off. 10.4V at all fuses when the ignition is on.  Not sure if that's abnormal.
I'm not sure about my meter.  I tested it on a 40W light bulb and get 27.4 ohms on the hundreds setting and get .027 on both the thousands and diode setting.
87 KZ1000 P1
Last edit: 18 Jul 2021 20:08 by badr0bot.
  • F64
  • F64's Avatar
  • 81-KZ440D2
18 Jul 2021 20:37 - 18 Jul 2021 23:11
#851989
10.4 Volts at all fuses seems low.
You may have a voltage drop somewhere.
meter on DC V
key on/ignition on
red probe on positive battery post
black probe on each fuse terminal
voltage should be close to 0 volts.
If voltage is more than 0.5 volts, then you have an issue between the positive battery post and the fuses.
It could be a loose positive battery clamp.
move red probe to negative battery post
black probe to engine case
voltage should be 0 volts
anything more than 0.5 volts indicated a bad ground connection
Again, could be a loose negative battery clamp to a corroded or loose ground connection to your frame and/or engine.
turn off engine
81-KZ440-D2.
LIC, NY
Last edit: 18 Jul 2021 23:11 by F64.
  • hugo
  • hugo's Avatar
  • '92 Zephyr 750
19 Jul 2021 01:31
#851994
How did you decide there is no spark?
  • badr0bot
19 Jul 2021 18:32 - 19 Jul 2021 19:28
#852067
F64,
I get .03 volts at the fuses with lights off but 1.5 volts with the lights on. Is that indicating a short somewhere in the lighting harness? With lights off, I also get full battery voltage at the fuses.
The ground appears fairly good at .006 volts differential. I checked the spark again with the lights off thinking that removing those circuits might remove the problem from the rest of the harness but still no spark. I also measured only .2 volts to the igniter when the starter switch is engaged.
Hugo,
I pulled each one and grounded it to the block.
87 KZ1000 P1
Last edit: 19 Jul 2021 19:28 by badr0bot.
  • F64
  • F64's Avatar
  • 81-KZ440D2
19 Jul 2021 19:14 - 19 Jul 2021 20:16
#852072
No short.
Just a huge amount of resistance along the 1.5V line.
The resistance will be between the two probes.
It could be corroded connections, loose connections, dirty terminals.
You can move the probes closer together along that wire till the 1.5V drops below 0.5v.
When the voltage drops you will have found where your problem will be.
Just for kicks..turn your headlight on.
meter on DC V.
black probe on positive battery terminal(the metal part of the positive battery cable)
voltage should be much less than 0.5V
If it's higher, then you need to clean or tighten the positive battery connection.
This tests your positive side battery connection.
Your ignition problem could very well be something else, but you do have a big issue along that section of 1.5V power wire.
The reason you didn't see it initially was because current wasn't flowing on that wire because your lights were off.
Your ground wire connection is excellent.
Fire up your starter for a couple of seconds. Pull a spark plug. Is it wet with fuel?
What Hugo said made me want to check for fuel getting to the cylinder.
When you measured voltage at the ignitor. Which color wire did you measure?
Where was the other probe?
81-KZ440-D2.
LIC, NY
Last edit: 19 Jul 2021 20:16 by F64.
  • badr0bot
19 Jul 2021 20:16
#852078
F64,
The battery connections are very clean, no corrosion at all and there is 0.00 differential voltage between the post and the cable. The plugs don't appear really wet but smell strongly of fuel. I pulled the hose from the back of the filter and the carbs are definitely getting gas.
87 KZ1000 P1
  • F64
  • F64's Avatar
  • 81-KZ440D2
19 Jul 2021 20:23
#852080
Which wire did you measure at the ignitor?
Your fuel system seems fine.
81-KZ440-D2.
LIC, NY
  • badr0bot
19 Jul 2021 21:53 - 19 Jul 2021 21:57
#852084
F64,
I measured the black and yellow at the connector that comes from the starter lockout switch. The other three wires go to the ignition coils.
87 KZ1000 P1
Last edit: 19 Jul 2021 21:57 by badr0bot.
