Ignition Switch Question and Running Light Problems,
  • F64
  • F64's Avatar
  • 81-KZ440D2
Re: Ignition Switch Question and Running Light Problems,
18 May 2021 16:51
#848711
The key switch must be set to the on position.  But you right hand kill switch can be set to off. That kill switch sends power to the coils.
81-KZ440-D2.
LIC, NY
  • Inspidship
  • Inspidship's Avatar Topic Author
  • 1980 KZ-550
18 May 2021 17:14
#848712
Well wouldn’t you know it I’m only getting voltage on one side of the red wires fuse. Is this a bad fuse for sure?
1980 KZ-550
  • F64
  • F64's Avatar
  • 81-KZ440D2
18 May 2021 17:39 - 18 May 2021 17:42
#848713
Could be a bad fuse or bad connector.
It depends on what part you touched with the probe.
I see 3 fuses.
Which wire combination is bad?
81-KZ440-D2.
LIC, NY
Last edit: 18 May 2021 17:42 by F64.
  • Inspidship
  • 1980 KZ-550
18 May 2021 17:47
#848714
The fuse ended up failing out into pieces, I think it was that. I’m gonna grab a few blade fuse holders and blade fuses to replace it. Hopefully it all works
1980 KZ-550
  • F64
  • F64's Avatar
  • 81-KZ440D2
18 May 2021 17:48
#848715
Sweet!
Fingers crossed
81-KZ440-D2.
LIC, NY
  • Inspidship
  • 1980 KZ-550
18 May 2021 18:27
#848716
I found a spare fuse in the box and it did indeed work! I’ll be upgrading to the blade fuses eventually but chugging along for now is the move I’ll make. Thanks kz bro!
1980 KZ-550
  • F64
  • F64's Avatar
  • 81-KZ440D2
18 May 2021 19:17
#848717
Glad to help!
Happy it was a simple fix.
81-KZ440-D2.
LIC, NY
  • Inspidship
  • 1980 KZ-550
19 May 2021 04:28
#848722
Me too, just a simple fix that made me give up a few months ago and 3 months later to find out it was a blown fuse
1980 KZ-550
