1978 KZ650SR poor charging.
Re: 1978 KZ650SR poor charging.
05 Mar 2021 12:13 - 05 Mar 2021 12:16Evobobber wrote: Problem solved. I got a new reg rect, done some tests and compared the old and new one. Looked like the readings with the old lack wire were suspect.
Put new one on and now it's working as it sould. A long test ride for me this weekend.
Thanks for the input and advice / help. Cheers
Good job.
What is the DC charging voltage at the battery at 4000rpm?
My 750 is very similar to your 650 but the charging system is 3 phase. The AC voltage from the stator was 75 VAC but the DC charging at the battery was still only 13.7 V until I got a new stator. The R/R was good. After replacing the stator the charging was back to normal at 14.5 VDC at 5000 rpm.
Last edit: 05 Mar 2021 12:16 by Nessism.
The following user(s) said Thank You: Evobobber
- Evobobber
06 Mar 2021 14:45 - 06 Mar 2021 14:46
My charge at 4k revs is just over 14 volts.
My next problem is to see why my 1/2 full tank gets empty by just sitting for a week in the garage. No obvious leaks and no smell of petrol fumes when I walk in.
I guess my own fault buying a non runner with no history. Still it puts a smile on to my face most of the time
Last edit: 06 Mar 2021 14:46 by Evobobber.
06 Mar 2021 15:41
How is your oil level???
- Evobobber
08 Mar 2021 00:34
My oil level is ok. It does smoke a little when i first start it sometines.
I think there is a fuel leak at / around the accelerator pump.
I took it for a spin and when i got back there was a drip there.
Thanks
Thanks
