While riding GPz550 cuts out and dies, able to restart then dies again
  • srsupertrap
  • srsupertrap's Avatar Topic Author
Re: While riding GPz550 cuts out and dies, able to restart then dies again
25 Oct 2020 15:45 - 25 Oct 2020 15:46
#837703
Thank you loudhvx & Ed.
I installed a set of used Dyna 3.0 Ohm green coils instead of modifying the wiring harness. I will have to verify whether the dying issue is resolved with a couple of test rides. The Dyna 2.2 Ohm coils both measured 2.1 ohms and are slightly discolored with yellow rings around the plug towers. Probably heat related.
Attachment DSCN0002.JPG not found
1981 KZ550 D1
Last edit: 25 Oct 2020 15:46 by srsupertrap.
  • srsupertrap
01 Nov 2020 15:45
#838112
Positive ride report: Took a 15 mile ride this afternoon and the GPz550 did not die once. :)
1981 KZ550 D1
  • Mikaw
  • Mikaw's Avatar
01 Nov 2020 17:13
#838114
srsupertrap wrote: Positive ride report: Took a 15 mile ride this afternoon and the GPz550 did not die once. :)
Thats the kind of report we like to hear
