1982 KZ750 electrical issues
- F64
- 81-KZ440D2
Re: 1982 KZ750 electrical issues
26 Aug 2020 17:55 - 26 Aug 2020 18:03
wow,
did someone do a rewire before you bought the bike?
That brown wire powers a lot of the bike.
Yeah, there may be shorts that you are dealing with as well.
We may just unplug everything and gradually plug things back in until we have an issue. Then we'll track it down.
81-KZ440-D2.
LIC, NY
LIC, NY
Last edit: 26 Aug 2020 18:03 by F64.
- Odin0311
26 Aug 2020 18:06
If you’re referring to all the taped on labels, no that was me making it easier for myself to process what went where and why. As far as I can tell the wiring harness is intact. I’ll ask the prior owner if he cut it open.
In the mean time I’ll unplug everything and follow your instructions. I really appreciate the help.
1982 KZ750 4
1977 KZ650 4
1977 KZ650 4
- F64
- 81-KZ440D2
26 Aug 2020 18:32 - 26 Aug 2020 18:42
just for kicks..
I think you have a break on that white wire.
meter DC V
everything connected
ignition on/engine off
remove the jumper wire to the yellow
black probe on negative battery post
red probe both side of the white wire fuse
note voltage
You have to find 12v on that white wire with the ignition on. Essentially, you would follow the white wire back to the battery until you find 12v. The area between the 0v and 12v on the white wire will be where your issue will be. It could be corrosion, pinched wire, bad connection....anything.
This is why you have to have the circuit on...When it's off you wouldn't see the issue.
turn off bike
meter DC V
note voltage
turn off bike
81-KZ440-D2.
LIC, NY
LIC, NY
Last edit: 26 Aug 2020 18:42 by F64.
- Odin0311
27 Aug 2020 21:55
Haven’t had a chance to check that next step yet. Do you have a recommendation on an aftermarket wiring harness? At this point I’m wondering if it wouldn’t be less of a headache to go that route. I was looking at the Ultima wiring harness. Designed for a Harley, my understanding is I’d need to switch to Harley style controls for the blinkers.
1982 KZ750 4
1977 KZ650 4
1977 KZ650 4
- F64
- 81-KZ440D2
28 Aug 2020 02:55
Yeah, I have no idea on that aftermarket harness.
That would be a big job, but it can be done.
81-KZ440-D2.
LIC, NY
LIC, NY
