Ignition
  • loudhvx
  • loudhvx's Avatar
Re: Ignition
01 Apr 2020 17:53
#822430
Yes, just remember that both plug wires from each coil must have a connection to each other or some common piece of metal.
The following user(s) said Thank You: Inspidship
  • Inspidship
  • Inspidship's Avatar Topic Author
  • 1980 KZ-550
Re: Ignition
01 Apr 2020 18:51
#822437
Little update, upon checking the spark plug caps, two of the caps are not showing any continuity, or resistance. So they are bad and just so happened to be one on each of the coils so the part where you said the plugs had to contact the same piece of metal, that wasn't happening. Im heading out to advance tmrw because by some miracle they are able to ship 4 caps in 30 minutes (same model as the ones on z1 im just impatient lol). More updates to come. This is just the first part of my adventure, still have to worry about fueling and the carbs and brakes. But that will come with time i suppose.
1980 KZ-550
