1979 KZ650-C3, Handlebar Switch Won't Close!
- mjudge
02 Jan 2020 18:28 - 02 Jan 2020 18:31
So...I purchased a '79 KZ650-C3 that had been down, and the handlebars on the right side had bent. I replaced the bars with ones I had from a '78, used the existing on/off switch. But now the switch won't close all the way when I put the screws in, and it's really pissing me off! I'm wondering if maybe the wrong switch is on there; not sure of the bike's history. Picture 1 shows the switch from the top, #2 the misaligned case. Anyone know if this is the correct switch for this bike? Thanks for your help!
Last edit: 02 Jan 2020 18:31 by mjudge. Reason: Need other photo
- loudhvx
Re: 1979 KZ650-C3, Handlebar Switch Won't Close!
02 Jan 2020 18:33
Some controls have a peg that have to fit into a hole on the bars. Does yours have this peg? I usually remove the peg on worn out controls (not pristine ones) since most KZ controls are made of metal and can clamp down hard enough to work without the peg.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
02 Jan 2020 18:36
Not sure on the 650 but I've seen a tit/pin formed into the top switch cover 0n my 1000 that has to engage into a hole in the bar... its there so you don't twist the entire control when grabbing a hand full of throttle
02 Jan 2020 19:02
Amazing! Yes, the KZ650 has a little peg that fits into a little hole in the handlebars. It is there to ensure that the control cannot twist out of position. Rather than getting pissed, the original poster should simply take a minute to examine the problem and correct it. Ed
- mjudge
02 Jan 2020 19:26
Hi Ed, I don't usually post anything here unless I'm really at my wits end...I didn't see or notice this after about an hour of fooling with it, but I'll check now and appreciate the help!
02 Jan 2020 21:01
Assuming the handlebars are stock there should be a hole for the pin to engage. If they are aftermarket and don't have the hole you can drill one. If so, ask first and maybe some one can help identify exactly where the hole should be drilled. Ed
03 Jan 2020 06:45 - 03 Jan 2020 08:01
Sans the hole. FWIW. In some old topics some say the hole & peg aren't necessary, so they grind off the peg. It has been surmised that the hole is just a locator to simplify the factory installation. I prefer to have the hole & not alter the housing.
I drill a hole using a titanium-coated drill bit. Before drilling, I make a dimple using a big nail & hammer. not sure if that's necessary, but I didn't want the drill bit to skate around on the new chrome. To protect the bars from scratches I wrap them w masking tape, plus milk jug plastic secured w masking tape near the hole.
Last edit: 03 Jan 2020 08:01 by martin_csr.
- gd4now
- Denco where did you go?
03 Jan 2020 10:15
Yes the pin and hole others are talking about should be looked at. Would also say take a look at the cable/wires going into the control unit. Stock they were inside the handlebar. Your pic shows that you are not running them through the bar. Make sure there is room, I cut a small hole in the lower control to allow the cable/wires to enter the control.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- Warren3200gt
03 Jan 2020 13:26I dont think they did on a c3. Thought it was only b's that had wiring inside the bars.gd4now wrote: Would also say take a look at the cable/wires going into the control unit. Stock they were inside the handlebar.
- Nerdy
03 Jan 2020 13:36martin_csr wrote: Sans the hole. Before drilling, I make a dimple using a big nail & hammer. not sure if that's necessary, but I didn't want the drill bit to skate around on the new chrome.
You know there's actually a tool for that, right?
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
The following user(s) said Thank You: martin_csr
03 Jan 2020 13:52Warren3200gt wrote:I dont think they did on a c3. Thought it was only b's that had wiring inside the bars.gd4now wrote: Would also say take a look at the cable/wires going into the control unit. Stock they were inside the handlebar.
Not just the b's. My 1977 KZ650-C1 came with the wiring inside the bars. I could be wrong, but I believe Kawasaki started putting the wiring outside the KZ650 bars in 1979. Ed
04 Jan 2020 06:02 - 04 Jan 2020 06:05
By Nerdy: You know there's actually a tool for that, right?
It's called a center punch.
Thanks. I don't have a that tool, but I do have a million nails. Do you know how many times I've needed a center punch?. Twice. maybe thrice. perhaps a few more times if I think hard enough. :laugh:
Last edit: 04 Jan 2020 06:05 by martin_csr.
The following user(s) said Thank You: Nerdy
