kz 750 doesn´t start
  • bikerebi
  • bikerebi's Avatar Topic Author
07 Dec 2019 01:28
#815021
hi
my bike doesn´t start
this bike was 5 years outside under a tree. it stands their because of this problem
i have this bike since 5 weeks. i have cleaned it.
my problem.. i have no spark. the coils are ne and have 11 volt.
the next problem is my english :-)))
i need simple tricks what i can do ????
thanks a lot and sorry for my english
  • riturbo
  • riturbo's Avatar
Re: kz 750 doesn´t start
07 Dec 2019 08:39 - 07 Dec 2019 08:40
#815040
You can start here Should be a manual for your bike in here www.kzrider.com/service-manuals
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Last edit: 07 Dec 2019 08:40 by riturbo.
The following user(s) said Thank You: bikerebi
  • bikerebi
22 Dec 2019 00:40
#815734
sorry... i was ill for a few weeks....
so on... i have checked my coils. this is ok. i have bouhgt two of them by e....
the same. i have seen.. i have a relais for my side columns but i couldnt find a wiring diagramm with this.
is this relais only for the german market ????
22 Dec 2019 07:02 - 22 Dec 2019 07:03
#815738
PLEASE show the exact year and model of your bike. Kawasaki made MANY different KZ750 motorcycles in both 2 cylinder and 4 cylinder models. Obviously there are major differences between the various years and models, so showing the exact year and model of your bike will help others help you. If you put that information in your signature line it will always show up. Thanks, Ed
Last edit: 22 Dec 2019 07:03 by 650ed.
  • TexasKZ
  • TexasKZ's Avatar
22 Dec 2019 12:37 - 22 Dec 2019 12:37
#815755
I am not sure about an extra relay, I have no idea what it would be for.
Eleven volts at the coil is too low. The battery should be close to 13 v, and there should be less than 0.5v loss at the coils. Either the battery is low or no good, or there are loose or corroded connectors between the battery and the coils.
As 650ed wrote, knowing exactly which year and model KZ750 you have will help folks provide good, specific help.
Last edit: 22 Dec 2019 12:37 by TexasKZ.
