Battery
Re: Battery
22 Aug 2019 06:14 - 23 Aug 2019 05:11
I'm currently using a Scorpion AGM from batterystuff.com. It's now exactly 2 years old & I keep in on a smart charger, hoping it will last longer than the previous one. which lasted exactly 2 yrs & it was 12.76 VDC straight out of the box & I checked it with a multimeter regularly. Since the voltage never dropped below 12.6 VDC, I only charged it once a month or so if I didn't ride enough. That battery never went more than a few weeks without riding the motorcycle or charging. This time I keep it on a smart charger to see if it will do better. I didn't want another walmart battery or a wet cell, and I don't think Yuasa offers an AGM for my motorcycle. I didn't see one anyway.
My motorcycle has a 3-phase charging system & Ninja 500 voltage regulator (credit to loudhvx for the reg-rec).
I use a VC97 digital multimeter & Ctek US 0.8 smart charger.
Last edit: 23 Aug 2019 05:11 by martin_csr.
Re: Battery
22 Aug 2019 11:58
I checked my alternator at 4,000 rpm and it's sending 55 volts on each phase to the solenoid/regulator. This is a bit below the 75 volts stated in the manual. Resistance is 0.7 ohm on each phase, which is a bit higher than the stated 0.48 ohm max. Overall the stator seems OK but the rotor probably has weakened magnets over the decades.
The solenoid checked out fine. Roughly 5 ohm in one direction and 100 ohm in the other.
Just for fun I started the bike on a spare battery and then removed the battery connection. The bike ran fine on just the alternator. Looks like my issue was a worn out battery. I have a new lithium battery on order. The AGM I had previously ordered was not available until Sept so I cancelled it.
- loudhvx
Re: Battery
23 Aug 2019 04:21 - 23 Aug 2019 04:34
The 550 manual has the voltage wrong. 75vac is for the 1-phase model. Your 3-phase stator should have about 55vac.
The most common way the regulator fails on 3-phase kz550's is gradually during a ride. Initial charging may show near 14v on the battery, but during a ride the voltage drops due to a failing regulator. For $7 or $8 its worth it to just throw a used ninja 250/500 reg rec on the kz55 as a test. Just splice the wires.
By the way, dont rev it too much without a battery or big capacitor. The regulator cant regular properly without something to smooth out stator pulses. People have melted headlights etc.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 23 Aug 2019 04:34 by loudhvx.
The following user(s) said Thank You: hardrockminer
Re: Battery
23 Aug 2019 05:29
Appreciate the information. I'll make a note in my manual.
