83 GPz1100 tps wiring sequence.
  • riturbo
  • riturbo's Avatar
Re: 83 GPz1100 tps wiring sequence.
03 Oct 2018 04:44
#791753
They came with a lot of turbo parts i bought . A popular mod for the turbo is to install 1100 throttle bodies on them . Pm me your address and Ill send one out to you .If it works you can buy me a case of beer or something . Rather see it on a running bike then on the shelf in my garage .
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
  • riturbo
  • riturbo's Avatar
06 Oct 2018 16:48
#791939
put it in the post this morning should see it by tuesday hope it works for ya :)
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
The following user(s) said Thank You: ned37
  • ned37
  • ned37's Avatar Topic Author
10 Oct 2018 10:24
#792124
riturbo, all i can say is thanks. it did the trick. still needs some adjustment that couldn't be done the way it was running.
sure is nice to be able to gently roll on the throttle without having to grip the tank with my knees.
i donated to the site.
thanks again.
'83 GPZ1100, '97 Triumph Trophy 1200, '08 Husky TE610
Verde Valley, AZ
  • riturbo
  • riturbo's Avatar
10 Oct 2018 14:07
#792130
That's great t to hear .Another one up and running .:) :)
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
  • ned37
02 Nov 2018 16:49
#793293
scirocco and riturbo: thanks a lot for you help. bike now running well.
after changing the tps, engine ran smooth, but i noticed it wasn't charging (plus, my trickle charger was not trickling, causing the bat to spit fluid), and the tach still jumped. i ordered a chinese regulator/ rectifier and used the 3 week shipping time to take a break and recondition the battery.
i changed it today and now it charges AND the tach no longer jumps. (p.s. the voltmeter on the dash is a nice decoration, but not much else)
thanks to everybody that helped.
Verde Valley, AZ
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
03 Nov 2018 02:20
#793311
Nice to hear you solve you TPS/Tach problem finaly.
  • riturbo
  • riturbo's Avatar
03 Nov 2018 05:24
#793313
Great job of sticking with it and getting it figured out .
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
