ignitor wiring zr550 23 Jun 2018 20:06 #785770
  • Zaddict
  • Zaddict's Avatar Topic Author
  • Enjoying my Zaddiction!
  • Thank you received: 48
Wow wow wow!!!! I take it back. I cranked up the advance 6 degrees and the bike just.wants.to.go.fast!! Holy crap. It’s like a freakin turbo. Changed the whole character of the ride. When not gunning it the bike is like a caged animal, kind of bucking/begging to go. Not smooth at all. But if I give her what she wants, man!
Also noticed popping on decel disappeared entirely.
I don’t think I’ll crank it up this high in the city, the bike is way too jumpy. But on these twisties :) :) :)
No pinging yet. Do I dare go to 8 degrees?
1990 Zephyr zr550 B1
Factory Pro Stage 1 jet kit
zx550 cams
SPII ignition system
Kerker stainless steel race exhaust with 1.5" competition baffle
K&N Air Filter...
Last edit: by Zaddict.
ignitor wiring zr550 23 Jun 2018 20:20 #785771
  • loudhvx
  • loudhvx's Avatar
  • Thank you received: 1615
Well, just be careful. Many people experience the euphoria just before things blow up :)
I wonder how hard it would be to add a knock sensor somewhere.
I'm curious as to what the 6 deg value means. The stock advance is way more than 6 deg, so is it 6 more than stock? I wouldn't have thought 6 deg would have been that effective.
ignitor wiring zr550 23 Jun 2018 21:20 #785773
  • Zaddict
loudhvx wrote: Well, just be careful. Many people experience the euphoria just before things blow up :)
Yikes. That's a scary thought. Now I need to research knock sensors. Though I'm thinking if something didn't blow during this past run, it should be fine. I was at or past redline many times.
I have the ignition curve at home, will post it when I get back. But yes, it's basically six degrees advanced over stock - all in at 43 degrees BTDC. I was hopeful that advance would help because I'm running the higher duration zx550 cams with stock 9.5:1 pistons. I'd read that one way to make up for lower dynamic compression is to add some advance. Don't know if that's what's happening, but something awfully fun is...
zx550 cams
K&N Air Filter...
ignitor wiring zr550 24 Jun 2018 11:43 #785805
  • Zaddict
Here are the curves
zx550 cams
K&N Air Filter...
ignitor wiring zr550 24 Jun 2018 13:48 #785820
  • loudhvx
  • loudhvx's Avatar
That's interesting. The SW+8 position is really only about 5 degrees more advanced than a Zx550 . Zx550's max out at about 40 deg BTDC.
So the SW 0 would have been retarded compared to a Zx550.
ignitor wiring zr550 24 Jun 2018 14:22 #785825
  • Zaddict
I’m very tempted to try +8 (45 degress total advance). Wonder if i should use higher octane gas. Still running 87.
zx550 cams
K&N Air Filter...
ignitor wiring zr550 24 Jun 2018 17:56 #785837
  • Zaddict
Averaged 45 mpg today. The highest I'd gotten since swapping in zx550 cams is 40mpg ... so something is more efficient now. So pleased with this new system!!!
zx550 cams
K&N Air Filter...
ignitor wiring zr550 27 Jun 2018 02:01 #785961
  • Wozza
  • Wozza's Avatar
  • Thank you received: 30
Yes for higher octane. if your going to push the ignition timing. You might not get pinging now but it might be a different story in hot weather
A knock sensor would be nice B)
1982 KZ550H1
Last edit: by Wozza.
ignitor wiring zr550 27 Jun 2018 03:29 #785962
  • Wozza
  • Wozza's Avatar
loudhvx wrote: That's interesting. The SW+8 position is really only about 5 degrees more advanced than a Zx550.
I think the biggest difference starts around the 3000 rpm point, theres 6-7 degrees more than the ZX550 and is more like the KZ550s 35 degrees @ 3200rpm mechanical advance then reaches full advance round 8000rpm instead of 10,000rpm on the ZX550's
loudhvx wrote: So the SW 0 would have been retarded compared to a Zx550.
Total advance might be less but its very similar @ 3000rpm, it might even have more advance up from there up to around 8000rpm than ZX550 ,
Im pretty sure i read the ZR's had 35 degrees total, itwould be nice to see the factory ZR550 ignition curve for comparison.
1982 KZ550H1
ignitor wiring zr550 27 Jun 2018 07:42 #785971
  • loudhvx
  • loudhvx's Avatar
But on a 550, 3000 rpm is nowhere near the power band really.
You would lose time looking for power at 3000 rpm. That would be downshift time or rev and clutch slip time. 3000 and light throttle would be fuel economy cruise mode, and that would be a slow cruise at that.
The kz advance down low is too much
, which is why the mechanical advance is a compromise. Lugging the motor that low while trying to get power would do bad things... Lots of knock. Which is why they went to electronic advance.
For power you would only be concerned with about 6000 rpm and up, maybe 5000.
I think the factory limits total advance in later years due to emissions.
ignitor wiring zr550 27 Jun 2018 08:33 #785972
  • Thank you received: 2828
loudhvx wrote: But on a 550, 3000 rpm is nowhere near the power band really.
Exactly!! As the Kawasaki KZ550 performance chart below shows at 3000 rpm (red circle) the engine makes about 17 hp while at 6000 rpm (green circle) it makes about 40 hp. Also, using stock gearing, in top gear 3000 rpm would only propel the bike a bit less than 40 mph. Ed
ignitor wiring zr550 27 Jun 2018 09:19 #785974
  • Wozza
  • Wozza's Avatar
Yeah i know there is very little power down that low i was looking a the graphs using 3000rpm as a starting point just for comparison purposes, thats all
The SPII has options for more advance at those rpm points. SW4 has 40 degrees advance @ 4500rpm , that's 5000rpm earlier than the ZX550 igniter,
zaddicts 43 degree total setting probably has 40 degrees @ 6000rpm and by his comments hes feeling it
i have read that some factory ignitors are suppose to have 35 and 40 degrees of advance @ 3500
1982 KZ550H1
