Bike Slowly Dies after 20 Minutes of Use
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: Bike Slowly Dies after 20 Minutes of Use
20 Dec 2017 08:37
#776403
Have you tested the coil? You can test them with a DMM, the factory service manual should list the ohm specs.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • loudhvx
  • loudhvx's Avatar
20 Dec 2017 08:47
#776404
Secondary resistance does not matter. It is only given to see if the secondary changed, indicating a failure.
All you need to know is the primary is 4 ohms, and the coil is a standard size coil for a classic motorcycle, and not a "mini-coil".
It can even be a bit higher, like 5 ohms, but 4 would probably be better.
There are usually quite a few options on ebay, some even look exactly like the stock coil.
  • TexasKZ
  • TexasKZ's Avatar
20 Dec 2017 18:31
#776439
  • k1z947060
  • k1z947060's Avatar Topic Author
21 Dec 2017 07:34
#776455
Thanks for the link - I found one or two 4ohm coils on eBay; but since they didn't have the 14.5k resistance at the plugs I didn't want to buy them.
After loudhvx clarified the secondary resistance doesn't matter, I will likely buy the cheaper 4ohm coil which better matches the bike's specs; unless you recommend otherwise.
1976 KZ400
  • loudhvx
  • loudhvx's Avatar
21 Dec 2017 10:34
#776462
The Dyna 5-ohm coils are known to work well with the points-driven Kz's. 4 ohm is a better match, but I think the 5 ohm coils should work just fine.
My bike came with 2.3 ohm coils, and they are the best match for the ignition, but I actually use 3 ohm coils and they work fine. I can feel no difference from using the stock coils.
That said, the Dynas are kinda pricey. I also have a set of no-name ebay coils that are almost identical to the stock coils and they worked great at about half the price.
