Help me test my rectifier
  • Topper
  • Topper's Avatar Topic Author
Re: Help me test my rectifier
12 Sep 2017 16:39
#770815
So I don't think my rectifier was the issue after all.
Tried that $30 rectifier. It didn't quite fit (despite claiming it would) but it fit well enough to test things out. No change. No charge.
So I checked everything out again. This time I discovered that while the stator tests fine at the stator, it did not test fine at the rectifier. Turns out I had a bad bullet connector on one of the wires running from the stator to the rectifier.
Problem seems to be solved. I'm getting 14.7v at the battery when I rev the engine with the old rectifier.
So going back to my original post, I think the rectifier actually passed both tests. I'm not sure why I got a reading in the 2000k range on the multimeter.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
  • SWest
  • SWest's Avatar
  • 10 22 2014
12 Sep 2017 17:01 - 12 Sep 2017 17:01
#770816
No eBay APP ID and/or Cert ID defined in Kunena configurationRegulator starting to fail? I just ordered SH 775 due to the bike taking time to get to 14.5v. I just hope it's not a knock off.:unsure:
Last edit: 12 Sep 2017 17:01 by SWest.
