Horn wiring ?
Re: Horn wiring ?
14 Jul 2017 11:53
#766938
To rule out a possible low bike battery or wiring issue, could test the Fiamm volume by short hot wire connections to a known good automotive battery.
Good Fortune! :)
  • kzdcw
  • kzdcw's Avatar Topic Author
  • 77' KZ1000A
Re: Horn wiring ?
14 Jul 2017 17:29 - 14 Jul 2017 17:30
#766961
Ed or Patton, Now I just connected the 2-wire female ends of my wiring harness and slipped them on the 2-male terminal ends of the Fiamm horn just like my stock KZ horn and made the sound comparison by pushing the horn button. Definitely not as loud as my stock horn.
Motorcycle battery is fully charged and wiring working perfectly with stock horn.
I know a relay has been suggested when using this horn but that wouldn't make any difference now in testing it would it ?
Even if I didn't use this Fiamm horn on my KZ, I wouldn't mine using it on my 75' Goldwing.
77' KZ1000A
Last edit: 14 Jul 2017 17:30 by kzdcw.
Re: Horn wiring ?
14 Jul 2017 17:46
#766963
[quote="kzdcw" post=766961............
.[/quote]
Considering the battery was fully charged I would have expected the Fiamm horn to be louder than the stock horn even without a relay in the circuit. Ed
  • kzdcw
  • 77' KZ1000A
Re: Horn wiring ?
14 Jul 2017 17:48
#766964
Sent a mesg. back to the seller, awaiting their response. Thank you for your responses !
77' KZ1000A
  • kzdcw
  • 77' KZ1000A
Re: Horn wiring ?
18 Jul 2017 19:25 - 18 Jul 2017 19:28
#767283
Patton and Ed, Ordered a Wolo Chrome Air Horn # 519 for my 75' Wing and instead of jumpering off my stock horn 2-wire harness connectors, I ran jumper wires directly off the battery terminals to the horn terminals.
Wow !!! Made me jump, really loud. So then I took the Fiamm horn I tested earlier but instead of testing it at the horn harness connectors like I did earlier, I used the same jumper wires as above for the Wolo horn and ran them to the Fiamm horn.
Same great results, nice and loud as referenced in this Post from other members.
So what gives ? Why are these horns working as they should coming directly off the battery, where hooking them up to the horn harness then using the horn button resulted in a lower noise output ?
77' KZ1000A
Last edit: 18 Jul 2017 19:28 by kzdcw.
Re: Horn wiring ?
18 Jul 2017 20:28
#767289
I can't answer that question since mine gets power directly from the battery via a relay rather than running through the horn button switch, small wires, etc. I'm a big fan of using a relay for the horn. Ed
  • kzdcw
  • 77' KZ1000A
Re: Horn wiring ?
19 Jul 2017 08:16
#767304
Yeah, I don't know either Ed ? Maybe the output voltage was suppressed to the Horn when just plugging into the harness and not using a relay, therefore a lower output volume of the Horn ?
77' KZ1000A
  • kzdcw
  • 77' KZ1000A
Re: Horn wiring ?
19 Jul 2017 11:15
#767307
Also, what gauge wires and fuse size are you guys using ?
77' KZ1000A
Re: Horn wiring ?
19 Jul 2017 13:08
#767309
For one FIAMM 72112 Freeway Blaster Horn (Low Tone - F) horn I used a 7.5amp fuse and 14 gauge wiring. Ed
