No match for stator-magneto combo! 21 May 2017 05:26 #762365
  • Apets1100
  • Apets1100's Avatar Topic Author
  • Thank you received: 1
Loudhvx thank you, I think you got a point with the extra power needed.. I'm pretty sure that my new stator is wrong.
I've got measurements of the rotor, but they are at the repair Shop. I can post them here in case that somebody can help
Tony
GP1100z B2
No match for stator-magneto combo! 21 May 2017 14:22 #762398
  • Apets1100
My rotor's measurements:
129 mm outside diameter
106 mm inside diameter
45 mm outside depth
Tony
GP1100z B2
No match for stator-magneto combo! 27 May 2017 13:40 #762885
  • Apets1100
Hi guys,
Reporting:The new R/R is on the bike, overcharging problem solved.
So, now i have a new stator which i can't use because it's for a different bike.
It's not useful to me, somebody else could use it but i have to know which bike it fits somehow..
Can I post measurements and maby somebody could identify it?
Tony
GP1100z B2
No match for stator-magneto combo! 27 May 2017 15:51 #762905
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2609
Glad to hear it. Yes, post it, maybe someone else can use it.
No match for stator-magneto combo! 31 Aug 2017 00:08 #770045
  • Apets1100
Sorry for the delay, that was a very busy summer..
I have the dimensions for the unneeded stator of mine:
bolt holes, center to center: 38mm
inside diameter: 35mm
outside diameter: 93mm
stator width:23mm
Tony
GP1100z B2
No match for stator-magneto combo! 01 Sep 2017 05:10 #770133
  • PLUMMEN
  • PLUMMEN's Avatar
  • Thank you received: 103
If its,for your z1/kz I'm pretty sure 73-78 900/1000 use same parts.
79-80 1000 used the newer style,I don't remember if they will fit the older crank
Although the 79 1000 Ltd still used a small pin crank,not sure if end of crank is same though.
